Just buy both and decide for yourself!
No more nonsensical than the OP.Sounds extremely expensive and makes no sense.
Was the Phase Ones almost 30k each when you bought it? I searched and got this: Phase One P25 first look, 22 megapixelI have Phase One p25 and P20 backs. both issued in 2004.
I also have an iPhone 7 Plus. Issued 2016.
The Phase one P20 has a 36x36mm sensor, the P25 has a 36x48mm sensor and the iPhone 7 plus has a 4.29x5.27mm sensor.
The P20 is 57 times larger than the iPhone.
The P25 is 76 times larger than the iPhone.
Which one do you think will shoot best?
And your point is??? Troll another site, OK?Was the Phase Ones almost 30k each when you bought it? I searched and got this: Phase One P25 first look, 22 megapixel
Impressive that there were 22mp cameras back in 2002, and makes sense why it was so expensive.
How would they compare to iPhone 14 pro's camera?
Here's the specs but I'm confused because it's not in a "number x number" format:
Key camera specifications: Primary: 48MP sensor, 24 mm equivalent f/1.78 -aperture lens, second generation sensor-shift OIS, Dual Pixel AF. Ultra-wide: 12MP sensor, 13mm equivalent f/2.2-aperture lens, Dual Pixel AF. Tele: 12MP sensor, 77 mm equivalent f/2.8-aperture lens, OIS.Oct 17, 2022
it's hard to compare because the specs for sensor are not in the same format. Asking for help from those who knows better.
Here's a good article on the topic: 5 Key Differences Between A Smartphone Camera and A DSLR Camera | The Smartphone Photographer You want to compare photos of the types of subjects you usually shoot as specs are apples and oranges.it's hard to compare because the specs for sensor are not in the same format. Asking for help from those who knows better.
First: I actually bought both both WELL used, at around $1K each.Was the Phase Ones almost 30k each when you bought it? I searched and got this: Phase One P25 first look, 22 megapixel
