Why you should own the best multitool
Discussion in 'Photography Beginners' Forum' started by kangnguyen, Jan 3, 2020.
  1. kangnguyen
    kangnguyen TPF Noob!
    Jan 3, 2020
    Having a multi tool is as important as having kitchenware. It means you will be able to use it every day. In this article, we bring you details about the reasons why you should carry one, and the key features of the top 5 best multi tools on the market.
    What is a multi tool?
    Before going into further details, let’s first explore what a multitool is. A multitool, as the name implies, is a handy tool used for performing multiple tasks and functions. It moves from side to side and works best for opening canned or bottled items, clipping things, removing a splinter, making a belt fit, and opening parcels. A multi tool usually comes with accessories and replaceable blades, wire cutters, and bottle or can openers, folding scissors, and screwdriver bits.
    [​IMG]
    Why should you own the best multitool?
    What is the best multi tool? The best multi tool is one that provides multiple tools and accessories that are used for many different purposes. For example, a Leatherman Surge multi tool offers up to 21 tools in one hand featuring replaceable wire cutters, a blade exchanger, and some outside-opening blades giving you access to any of its 21 premium tools inside the body.
    ➠➠➠ You Might Also Enjoy: https://thekinglive.com/looking-for-the-best-multitool-find-your-one-in-a-thousand.html
    Today, there are many multi tools that come in different designs, weight, length. In general, a multi tool is still one of the most powerful tools that you can get for yourself. Here are the top 6 reasons why:
    1) For clipping things
    Imagine if your manager asked you to clip more than a hundred coupons for the company’s sales promotion program... Do you think a normal pair of scissors will help you much? Maybe it will, but it takes you a long time to complete the task. Having said that, it might be a hard challenge to cut a straight line on paper using a usual scissor. A better solution here is, if you carry a multi tool, you will find it easy to clip vouchers without any unexpected cut line. Meanwhile, your time is saved effectively.
    2) Open canned or bottled items
    A multitool can be used as a “can opener” or “bottle opener”. It is ideal to use for opening packed food and beverage items such as wine, beer bottles, milk powder, beans, and canned fish . Besides that, you can use it to open a paint can. With less than a minute, your canned stuff is perfectly opened and ready to consume or use.
    3) Remove a splinter in your skin
    When you have an unexpected splinter stuck under your skin, there is nothing better than having a multi tool ready on hand. Many modern multitools come with tweezers (even though they do not come in the traditional design) or you can use the fine tip of the knife blade to take out that splinter from your skin. If you do not have any multi tools, consider buying one now.
    4) Make your belt fit perfectly
    Do not throw your belt away if it does not fit your body perfectly! You can use a multitool with an awl to add another notch. Not all, in a similar way, a multi tool can be used to extend or shorten the length of ladies’ belt bags. You do not need to seek help from others since you can “do it yourself” within just 30 seconds.
    5) Open an envelope, parcel, carton box
    Carrying a multitool will help you much in opening stuff like an envelope, a parcel, or a carton box. If you are a “fan” of shopping online and your items are delivered regularly to your house, we trust that you will find it convenient to have a multi tool with you. Furthermore , a multi tool is safer for use, compared to if using another long sharp knife.
    6) Replacement of batteries
    Sometimes in life, you might need a screwdriver, but it is not always available when you truly need it. This might be the moment when you wish you had a multi tool. For example, if you need to replace batteries in items such as a traditional clock, kid’s toy, and a weight scale, a multi tool can perform a job as excellent as what a usual screwdriver does. It helps to turn screws quickly, while you do not have to find your screwdriver.
    Features of the best multitools
    The above was just about listing the top 6 reasons why you should carry a multi tool. Remember that it is not a full list of how this tool could make your life easier. It will be an omission if we won’t look at the best multi tools available on the market. Here are the top 5 best multi tools for you to consider:
    1. Leatherman Surge Multi Tool
    • 21-in-1 multi tool. This is the most useful multi tool
    • Star rating: 4.6/5 (773 ratings)
    • Price: $114.95
    • One of the top rated multi tools
    • Weight: 335g (12.5 oz)
    • Closed length: 3.1 in (7.87 cm)
    • Heavy-duty workhorse with extra-large scissors, full-size knife blades
    • Replaceable wire cutters
    • One-handed operation
    2. SOG Multitool Pliers – PowerAssist Multi Tool Pocket Knife
    • 16-in-1 multi tool
    • Star rating: 4.4/5 (704 ratings)
    • Price: $74.95
    • Weight: 272g (9.6 oz)
    • Closed length: 4.6 in (11.68 cm)
    • Overall length: 7 in (17.78 cm)
    • Blades with one-handed operation
    3. Leatherman – Wingman Multitool with Spring-Action Pliers and Scissors, Stainless steel
    • 14-in-1 multi tool
    • Star rating: 4.7/5 (3,252 ratings)
    • Price: from $47.95
    • Best rated multi tool on the market
    • Weight: 198.4g (7 oz)
    • Closed length: 3.8 in (9.7 cm)
    • One-hand opening
    4. Gerber Suspension – NXT Multitool with Pocket Clip [30-001364
    • 15-in-1 multi tool
    • Star rating: 4.5/5 (651 ratings) – A good multi tool with an affordable price
    • Price: $29.97
    • Weight: 181.4 (6.4 oz) – extremely lightweight compared to other 4 suggested multi tools
    • Length: 4.25 x 1 x 4.25 inch
    • The needle nose pliers are spring-loaded thus it lessens hand fatigue
    [​IMG]
    5. Leatherman – MUT Multitool, Stainless Steel Sheath
    • Star rating: 4.5/5 (553 ratings)
    • Price: $144.95
    • Weight: 317.5g (11.2 oz)
    • Closed length: 5 in (12.7 cm)
    • The first multi tool that functions as a practical and tactical tool for military, law enforcement, or civilians
    Conclusion
    This article listed some of the benefits of carrying a multitool, and suggested options from the best multi tool brands such as Leatherman, Gerber, and SOG. But it is not a full list of what and how a multi tool could bring joy to your life. If you are looking for the best multitool reviews, spend a few minutes to visit TheKingLive website at thekinglive.com to read the best in class reviews, as well as other helpful articles!
  2. TWX
    TWX No longer a newbie, moving up!
    Apr 30, 2019
    410
    103
    Controlled setting?
    How about just setting up some regular lights, and play with bulbs of various wattage and color-temperature?
    Could even go fancy and make your own reflectors.
    When I would take pictures of small items for sale for sites like Craigslist, I would just use a couple of these:
    and play with things like distance, height, aim, and particular bulbs until I got what I liked.
    Admittedly I am no professional, I just play with things until I get a result I like and then try to remember what I did to use next time if possible.
  3. AQS
    AQS TPF Noob!
    Dec 23, 2019
    38
    8
    For lighting, I go to Hornbach (like Home Depot) and buy flexible, dim-able LED strip lighting. You can pick between the different colours (bright white, softer white etc). They aren't expensive and you can adjust the amount of light you want to use and shape it into any form you like, or add addition "strips" if you need more. Pretty versatile.
    You can also place it inside am open-ended box or angle the light using some white board to get spot lighting etc...
  4. smoke665
    smoke665 Been spending a lot of time on here!
    Mar 29, 2016
    12,086
    5,913
  5. Sharpshooterr
    Sharpshooterr No longer a newbie, moving up!
    Feb 5, 2019
    253
    66
    NorCal, North Bay, USA
    K, you don't give us much to go on?
    Are you using pure ambient light?
    Indoors? Outdoors? Day? Night?
    Maybe you just need a $75 Neewer LED light!
    SS
