- Joined
- Sep 2, 2003
- Messages
- 34,516
- Reaction score
- 7,544
- Location
- In the mental ward of this forum
- Can others edit my Photos
- Photos NOT OK to edit
Definitely easy to work, with due to its size. Plus right now, it's ALL you're going to work with because of the base you're getting with the Daylab. Most of them ship with the standard 3x4. The beauty is if you do become totally smitten with the process, you can purchase the base and film holder that takes 4x5 sheet film - woOt!hobbes28 said:Is 669 the easiest to work with. I still haven't decided if I want to try a lift or a transfer first...or if they're similar enough to try both.
But it's best to start the small, less expensive way. Do you have an art supply store nearby? You'll want to go pick up a large sheet of hot-pressed watercolor paper - I like Arches the best. And you'll need a brayer.
Lifts are probably easier than transfers....involves hot water so keep the boys back. How much do you know about the processes?
