mathbias
- Joined
- Nov 28, 2021
- Messages
- 67
- Reaction score
- 6
- Can others edit my Photos
- Photos OK to edit
One of my intended uses of my new Sony a7 iii is to document progress of plants in my garden (and see what I'm doing right/wrong in gardening). I got the camera at the wrong time of year for that. But today I took some test photos as if I were doing gardening photos, so I can learn what I'm doing right/wrong in use of this camera. With my old camera, the background spoils most gardening photos. With the new camera, I assume min F of my zoom lens together with widest aperture gets rid of background, as I did in these two tries.
These need improvement and I have no clue of even what I did worse the second time. I thought I did pretty much the same thing other than a tiny shift of angle.
In both cases, I used the AF because I'm hopeless at MF. In both cases I used the digital zoom to assist AF and the smallest spot choice of AF and carefully focused on a leaf that is an average distance (vs. all the other leaves of the plant) from the camera. I'm pretty sure I made a good selection, but I'm also pretty sure in the first photo that the actual focus is on a point too near the camera. So far as I can tell on a big computer monitor zoomed in to parts of the photo, pine needles closer to the camera than any of the leaves are in focus, while everything even a little further than the point I chose to focus on is out of focus. So I'm pretty sure the AF failed me. But please tell me if I've misinterpreted what is wrong.
The MF on this camera is just too hard for me to use, as is the DMF (supposed fine tune after AF). If I could tell which way the focus was off, or if I knew which way it would consistently be off (for a specific set of conditions) I would fine tune the focus by using AF then physically moving the camera slightly further away or closer. But I really can't tell with either the viewfinder or the monitor. I never know till I get back to a desktop computer. So my only hope is to understand what is going wrong in enough test photos to be able to blind compensate for it in real photos.
Then in the second photo, it is just worse and I have no idea what changed. It looks to me like less depth of focus, but no settings on the camera changed and I'm barely more than guessing when I say less depth of focus. Less depth of focus would actually be good, but combined with the focus being closer than the spot I carefully focused on, it would be the reason the second photo is just a failure (compared to the first photo needs some improvement).
