+ Reply to Thread
Results 1 to 11 of 11
  1. #1
    Join Date
    Dec 2010
    uk
    Posts
    12
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Need help on understanding dslr camera and lenses system
    I want to buy a dslr camera and a first lens with it. Im confused on how the system works. heres a few questions.
    1. does the camera have the aperture settings or is it the actual lens which has the settings?
    2. ive seen some lenses which state only 1 aperture for example "eos 50mm f/1.8" does this mean i can only use the lens at this aperture?
    3. Is there a lens which can cover everyday shooting for example. decent focal range, decent macro, a bit of zoom, full manual aperture, shutter, iso settings. Something like the bridge cameras but having it in a lens version instead. (doesnt have to have the superzoom feature)
    Thanks in advance. I might be asking more questions so please bear with me. Im new to photography and would like to get into it.
  2. # ADS
  3. #2
    Join Date
    Sep 2007
    Minneapolis, MN
    Posts
    917
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    4 times
    1. The lenses determine aperture restrictions (i.e. 1.4 or 4-5.6). However the camera body is used to SET the aperture.
    2. Lenses with one aperture are stating their largest aperture. This means a lens that has a zoom range of 18-55mm with f3.5-5.6 can shoot at 18mm at f3.5 but only down to 5.6 when zoomed all the way in at 55mm. Higher quality glass like the 24-70mm 2.8 can stop down to 2.8 throughout the entire zoom range.
    3. Yes, there are 24-105, or 28-135mm or even a 18-200mm. However, don't expect one of these lenses to do everything perfectly.
    I'm probably not explaining this very well, but someone else will come along and fill in the gaps. Welcome to the forum.
    The things you own, end up owning you. - Tyler Durden
  4. #3
    TPF Junkie!
    Join Date
    Mar 2008
    Posts
    6,503
    My Gallery
    (0)
    Liked
    255 times
    Quote Originally Posted by saabuldin View Post
    This is dependent on the lens.
    The aperture shown is the widest aperture at which the lens can open up to. A lens with just f/1.8 will have a widest aperture or f/1.8. A lens that is labeled f/3.5-5.6 has an aperture that changes as it zooms. As the lens zooms in, the widest possible aperture gets narrower and narrower, going from 3.5 to 5.6.
    3. Is there a lens which can cover everyday shooting for example. decent macro, a bit of zoom, full manual aperture, shutter, iso settings. Something like the bridge cameras but having it in a lens version instead. (doesnt have to have the superzoom feature)
    There are lenses that are that serve a general purpose, but they usually will not be good at different kinds of specialty work. General purpose lenses, like a lens that will zoom from 18mm to 200mm will usually not be as good quality as say a prime or a shorter ranges zoom. Prices will usually reflect this.
    You can buy 70-300 zoom lenses with a variable aperture that's widest aperture changes with the zoom, as explained for your second question, for about $300. Canon and Nikon both make 70-200 f/2.8 Lenses with some sort of image stabilization that are better than the 70-300 variable aperture lenses. They cost about $2,000-$2,500.
    My name is Will. You may call me Will.
    -Will
    Slough Roast Blog
    Capitol Sound Blog
  5. #4
    Join Date
    Dec 2010
    uk
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by AverageJoe View Post
    yes i understand now but does that mean at 18mm focus, i can open up aperture to like f/22 if the camera lets me.
  6. #5
    Join Date
    Mar 2010
    New Jersey
    Posts
    667
    My Gallery
    (0)
    Liked
    1 times
    You have the idea backwards. Smaller numbers = larger apertures and larger numbers = smaller apertures ... opposite of what seems logical to non photographers. The answer to your question is if a zoom lens has a fixed largest aperture (say 2.8) you can use the zoom at that f stop throughout the zoom range. All lenses will be able to close (bring the f stop to a larger number) their aperture to the lowest they can go without any problems. But as you close down the aperture you need to compensate for the lack of light and lenses can have image quality issues.
    And 18mm is a focal length vs focus.
    Buying a Nikon doesn't make you a photographer. It makes you a Nikon owner. ~Author Unknown
  7. #6
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,791
    My Gallery
    (4)
    Liked
    579 times
    Yes - but you would be stopping down, not opening up.
    3.5 (or whatever it might be) is just the maximum aperture possible on the lens. You can still use smaller ones (which would be a larger number).
    -Josh
    Flickr
  8. #7
    It's all about - Light Site Moderator
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,104
    My Gallery
    (1)
    Liked
    1750 times
    Yep! Aperture values are fractions of the lens focal length. So f/2 means the lens aperture diameter is 1/2 the lens focal length, and f/4 means the lens aperture diameter is is 1/4 the lens focal length.
    Obviously, lens focal length is a variable. A zoom lens zoomed to 100 mm that has the aperture set to f/2 has a lens opening that is 50 mm wide, and 25 mm wide when set to an aperure of f/4. A 200 mm lens set to f/2 has a lens aperture diameter of 100 mm, etc, etc, etc.
    In other words the letter f = 1, and with fractions, the bigger the bottom number the smaller the value.
    Lenses that have a range listed , like an 18-55 f/3.5-5.6 lens are called variable aperture lenses, because the maximum aperture changes automatically when the lens is zoomed from 18 mm to 55 mm. Lenses that have a single number like a 17-55 f/2.8 lens are called constant aperture lenses because if set to f/2.8 at 17 mm and then zoomed towards 55 mm the lens stays at f/2.8.
    Variable aperture lenses are less expensive than constant aperture lenses.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    "Even the easy things are tough, if you do them half-heartedly"
    FOR SALE : Stay Tuned!
  9. #8
    Join Date
    Apr 2008
    Heart of Dixie
    Posts
    609
    My Gallery
    (0)
    Liked
    1 times
    KmH explained it well. The EF 50mm f/1.8 lens can open up to as large an aperture as f/1.8 (50mm ÷ 1.8 = 28mm opening). It can stop down as small an aperture as f/22 = 2.2mm opening. It can do this in steps of 1/3 of an f-stop.
    f-stops are useful because they tell us something about exposure. Each number of f-stop goes up by the square root of 2, and each f/stop cuts the amount of light reaching the sensor in half compared to the previous one: f/1.4, f/2.0, f/2.8, f/4.0, f/5.6, f/8.0, f/11, f/16, f/22, f/32.
    Comparing the EF 50mm f/1.8 lens to the EF-S 18-55mm f/3.5-5.6 lens, we see that when the 18-55mm zoom lens is zoomed in to the 50mm focal length, it has a maximum aperture of f/5.6. That gathers just one tenth as much light as f/1.8.
    Back to your question about a general purpose lens. If you get a recent Canon EOS DSLR, it's probably going to come with the EF-S 18-55mm f/3.5-5.6 IS wide-normal zoom lens in the kit. This focal length covers a great deal of useful photography. You can take a lot of good photographs with the kit lens. If you want to shoot with shallow depth of field or in low light, the EF 50mm f/1.8 lens is a very inexpensive addition to your kit (about $100). If you want to bring far away objects closer, the EF-S 55-250mm f/4-5.6 IS telephoto zoom lens can do that (less than $300). You can of course get larger, longer or more professional lenses that cost thousands of dollars, but these three lenses can cover a very large range of photography.
  10. #9
    Join Date
    Dec 2010
    uk
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    thanks to everyone.
  11. #10
    Join Date
    Nov 2010
    Posts
    38
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by KmH View Post
    Question: On the standard consumer zoom lenses, is the aperture "fixed" to the focal length?
    For example, say we have a 70-300 f/3.5-5.6. Wide open the aperture is 3.5. As I "zoom in" on a subject the aperture changes (larger numbers, smaller opening, obviously). Is the aperture on these type of lenses always fixed to the focal length?
  12. #11
    Join Date
    Sep 2007
    Minneapolis, MN
    Posts
    917
    My Gallery
    (0)
    Liked
    4 times
    For example, say we have a 70-300 f/3.5-5.6. Wide open the aperture is 3.5. As I "zoom in" on a subject the aperture changes (larger numbers, smaller opening, obviously). Is the aperture on these type of lenses always fixed to the focal length?[/QUOTE]
    Yes, if you set your lens to f3.5 at 70mm and start zooming in, you'll notice the aperture values change as you zoom in and once it zooms all the way into 300mm you'll notice you are at f5.6 and you won't be able to open back up to f3.5 unless you zoom all the way out.
    This is why the expensive lenses, say the 70-200mm f2.8 has only one aperture value associated with it, it can be opened all the way up to f2.8 throughout the entire zoom range.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Understanding lenses, can anyone teach me?
    By Photo Marksman in forum Photography Beginners' Forum
    Last Post: 02-15-2011, 04:49 PM
  2. Camera Bag for DSLR and three lenses
    By alinikon in forum Photography Equipment & Products
    Last Post: 01-16-2011, 03:02 PM
  3. Understanding Lumix G and lenses
    By skeen in forum Photography Equipment & Products
    Last Post: 01-05-2011, 06:18 PM
  4. Replies: 0
    Last Post: 05-21-2010, 11:07 AM
  5. Am I Understanding Lenses Correctly?
    By Glasticart in forum Photography Beginners' Forum
    Last Post: 03-10-2010, 05:05 PM
help understanding lenses
understand dslr camera lenses
understanding camera lenses dslr
understanding dslr camera lenses
understanding dslr lenses
understanding lenses dslr
understanding slr camera lenses
understanding the lenses on dslr cameras
what does f 1.8 aperture mean
what does f 1.8 mean
