Canon 20D
Discussion in 'Photography Equipment & Products' started by soccerdad, Mar 13, 2006.
  1. soccerdad
    soccerdad TPF Noob!
    Mar 13, 2006
    Im going digital. The package im looking at is the Canon 20 with a2GB compactflash card form B&H. My question is the lens im looking at is 70-300mm f/4.5-5.6 IS USM. my main goal is soccer photos. Is this lens "fast" enough? and is the IS needed for sports. I have a EF 35-135 USM from my 35mm EOS rebel.
    Any help or suggestions welcome.
  2. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Hi soccerdad,
    I've just moved this thread to an appropriate section, where you will get more views/responses.
    Welcome to TPF!! :D
  3. Peanuts
    Peanuts TPF Noob!
    Jun 16, 2005
    2,905
    85
    Canada
    Someone on here who has done sports photography before will be able to help you much better, but I am certain a main question will be if soccer is indoor or outdoor? If outdoor, I am certain this lens will be fast enough in most conditions, but it may struggle somewhat indoors depending on the lighting. I have used this lens, and speaking from that experience, it does a fantastic job, and the IS is indispensable.
    P.S. Welcome! :)
  4. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    It will really depend on the light. If it's bright, then the lens should be OK...but if the light is not very bright...you will have a hard time getting a shutter speed that is fast enough to freeze the action.
    The 20D performs well at high ISO...so if you don't mind some digital noise, you can crank the ISO up to 800, 1600 or (H) 3200 to help freeze the action.
    IS is nice, because it helps to eliminate camera shake when shooting hand held...however, it will not help to reduce blur from subject movement...only a fast shutter (or flash) can do that. The IS would be helpful for getting a clearer shot when the action is not so fast though. Some IS lenses have a 'Pan' mode...which is to be used while on a tripod or mono-pod. This might help but I don't know if this lens has that option. Essentially, IS is not a substitute for a wider aperture when it comes to sports.
    If you can afford a faster lens, that would be ideal. The 70-200 F2.8 is well renowned but it's heavy and expensive. Sigma makes one that is cheaper and almost as good. There is also an F4 version of the 70-200, which is a good lens but not much faster than 4.5-5.6
