Canon 2x Extender
Joe S
Website
www.wheatonsportsphoto.com
Has anyone else had a problem getting crisp clear focus with this? I am getting rather frustrated with the quality of the images through it.
an example of the soft focus
Camera: Canon EOS Digital Rebel XTi Exposure: 0.004 sec (1/250) Aperture: f/5.6 Focal Length: 400 mm ISO Speed: 1600 Exposure Bias: 0/3 EV Metering Mode: Pattern
The focal settings were AI Servo with the focal area set to full range , I may try center focal point next, or sell it and pick up the 1.4x. Any suggestions are more than welcome.
Unfortunately, that is inherent with all teleconverters, especially the 2x. You are losing 2 stops of aperature and autofocus in most cases. Better quality is to be had with the 1.4X. What lens are you using? Hand-held, tripod? At 400mm, a solid tripod will help immensely even with IS. 1/250 is a bit slow for moving subjects like you have also so the softness can come from that. Try the 1.4x, but faster glass is the true solution.
IS that a true 400mm lens, with the 2X adapter as well?...or is it a 200mm lens with the 2X? What lens?
The 2xTC isn't the best example of Canon optics, imo. The 1.4x is much sharper.
That said, the shutter speed comment above, regardless of IS, is right on.
ok, I understand the shutter speed issue, I tried to correct this with the high ISO because I was loosing light quickly. The sun was already below the horizon, maybe during the best light I will have better results at a higher shutter?
And I will try to keep from shooting wide open when possible, thank you.
Any further insight is more than welcome.
oh, and I was on a monopod
What is the distance between your camera and your subject(s)? If it is about 50 feet, then the total DOF is about a feet (with F5.6). And sometimes, you may not be able to get the subject or all the subjects in focus.
the shot above was most likely at least 50 feet away, I was at the end line and they were past midfield so that may well be 60-70 feet away so that raises another excellent point. Thank you Dao
I use that exact combo a lot. 70-200 and a 2x ( not mkII) I am told the MK II is much better. Anyhoo ~ if you want it sharp you GOTTA stopp down to f8 and bump up the asa if you need to freeze action .
Most lenses are better when stopped down, but this is one of the best telephoto zoom lenses around. Even at F2.8, it's usually pretty good.
You might consider loosing the TC and just shooting at 200mm...then cropping afterward. It won't help if you are making large prints, but for smaller prints and web viewing, it should be fine.
Also, are you using mode 2 on the IS? It's meant to be used when on a mono-pod so that it only corrects for motion on one plane. If in mode one, it might actually be giving you blur.
Keep in mind as well, and extender, be it the 1.4X or the 2X will affect the auto focus speed as well. The are not really suited to fast action photography. The 2X is also not really suited for anything less than the 300mm and is better on the 400mm and above.
you guys are a wealth of ideas and advice. Thank you very much. I am certain that the next event will turn out better.
