VidThreeNorth
- Joined
- Oct 21, 2016
- Messages
- 1,176
- Reaction score
- 214
- Can others edit my Photos
- Photos NOT OK to edit
Main Camera "2x Zoom" (digital enlargement)
This set of images is using the main camera but at "2x" digital zoom (enlargement). If you understand the technology, then the obvious result is that the focus distance should be the same, and the number of pixels used to portray 1mm of an image should be 2x, but since the lens and sensor have not changed, the detail and "optical resolution" should drop proportionally meaning one "gains nothing" by doing this. If this is not true, then something odd is happening.
I still have not had the time to do any calculations, and it might be a long time before I do. Moreover, when I do my work, I might not cover a calculation that you would like done. Put simply, I don't care. You have close enough to the same base images that I have to work from, and you can do your own math. If you do, then you can post your results and we'll all learn what you found out.
"Mn2x_0005a-crop1600-C1.jpg"
- Crop from 620,480
"Mn2x_0005b-rsz1600-C1.jpg"
- Crop from 620,480
