Changing apeture settings
Discussion in 'Beyond the Basics' started by wwwursa, Feb 15, 2008.
  1. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    On my finpix s7000 the auto mode is set for 2.8 apeture and the pictures are fine.. However, want to get more depth on my close ups.
    Since I am using a tripod, the lenght of time is not a problem so I want to set the apeture to as low as possible which if 8. I assume I am going to get the same picture but with more depth. However, virtually everything has changed, lighting,color, etc. It says the ISO is 200 in such a circumstance.
    Is ther any way to get more depth without cahnging everything else?
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Normally, you are right, if you change the aperture (and change the shutter speed to suit) nothing should be different except the Depth of Field.
    I'm guessing it's got something to do with how your camera is programed.
    What mode are you using? If you have aperture priority, that would be the one to use.
  3. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    I normally am in the "Auto" mode. But to get more depth I change the mode setting to "A" which I assume stands for "Aperture". In that mode I can change the Apeture setting and the time changes at the same time.
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That's right. We call that 'Aperture Priority Mode'. You choose the aperture and the camera gives you the correct shutter speed, based on the reading from the light meter.
    I'm not sure why other things would change...they shouldn't.
  5. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    I just went and took the same shot in "apeture" mode but at 2.8 as in the auto mode. The resulting backround color was much more pink.
    I also noticed that as I changed the mode setting from "Auto" to any other mode the color dramatically changed in the image finder.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Are you using the flash?
  7. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    No Flash
  8. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I don't know....
    Maybe it would help if you posted a couple examples (with problem and without) and also posted the EXIF data, so that we can all see what is going on.
  9. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    Where do I obtain exif data?
  10. Sun Devil Rob
    Sun Devil Rob TPF Noob!
    Feb 14, 2008
    33
    Phoenix, Arizona
    It should appear on you LCD screen when viewing your image.
  11. wwwursa
    wwwursa TPF Noob!
    Nov 24, 2007
    25
    Could it be that in the default "auto" mode white balance is not on and in the Apeture mode it is?
    Will play with this to see if it is the problem.
    I found that exif is a format with info attached to it. Will explore this also.
  12. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Many image programs will display this data, it's pretty much a list of all the settings on the camera. Just cut and paste it from the software into your post, along with the image.
