Chattanooga TN Pano 21 pic stitch
Discussion in 'Photography Beginners' Forum' started by Hooker771, Jan 13, 2010.
  1. Hooker771
    Hooker771 TPF Noob!
    Oct 20, 2009
    332
    I took this one these this evening on my way home. I think it turned out pretty good. I still give thanks to this forum and specifically bitter J for the tip on live view not focusing. These were handheld, and next time ill use the tripod at dusk (didnt have it with me.)
    [​IMG]
  2. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    'tis a cool pano
  3. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    Thats pretty cool. I still see a little bit of banding, if I nit pick. Only important if this was to be printed large and sold. How did you go about metering this one.
    Also I'd love to see this bigger, can you post it, say, 2000ish pixels wide? I know it won't fit on the screen. But I really want to get into the image :thumbup:
  4. Hooker771
    Hooker771 TPF Noob!
    Oct 20, 2009
    332
    Bitter, im not really sure how to do that as far as pixels go and im not going to sell it but may blow it up a bit and print for my office. Im going to keep going back until I like it, I brought my tripod today just in case. The "Original" is over 10,000 pixels on my flickr account and way too big to post here. It is a bit grainy due to me shooting at 400 iso im afraid, so I have something else to try tonight. Below is a single shot from last night, this is not one from the pano. As far as metering, I have all the settings on manual and as I rotated my body/camera around I would adjust the shutter speed to try to keep the needle in the middle. Not very scientific but when the sun is setting and the light so different from one side to the next it seemed easiest to do. I also shot all of these shots at ap 2.8 for the light, but may try to up that with the tripod.
    Suggestions on technique?
    If you want to see the original size you can go here, as I dont know how to reduce it to 2000. If someone else wants to that is fine by me.
    http://www.flickr.com/photos/hooker771/4272365681/sizes/o/in/photostream/
    [​IMG]
  5. Bitter Jeweler
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    You can change the size using pixels as your variable in most editing softwares.
    Ah...I believe you need to set your exposure once and take all the shots. In your image it goes from (the sky) dark to light, so I would meter the middle, then start taking the sequence with the same settings throughout. You changed your settings, metering for each segment, thus the banding.
  6. Hooker771
    Hooker771 TPF Noob!
    Oct 20, 2009
    332
    Ill try that. Thanks.
    I just thought the left side (more shadows) would be too dark.
  7. fokker
    Jun 23, 2009
    2,830
    294
    New Zealand
    Yeah I was always under the impression that you would want to set the camera to one exposure settting in manual mode then just take all the pics at that same setting. In my experience this does tend to show the sky (in particular) going from dark to light, or vice versa, but it's gradual and often looks natural anyway. Having bands between you've stitched the photos together would be far worse IMO.
  8. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    also, one thing you can do is tie a string with a weight at the bottom to the front(? I think) of the lens. Then as you rotate make sure the string stays in the same spot. The rotation should be around the lens not the camera (not that it will make that much of a difference).
  9. Bitter Jeweler
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    Ah, so you pivot from the lens, rather than at the tripod?
  10. fokker
    Jun 23, 2009
    2,830
    294
    New Zealand
    Can't see it making a big difference when you're shooting something relatively far away. If it was something quite close then I guess it would be the right way to do it.
  11. Hooker771
    Hooker771 TPF Noob!
    Oct 20, 2009
    332
    Seems like if you were close up that would make it look more fish eye? I cant wrap my brain around it, but will try it one day.
  12. Bitter Jeweler
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    Look up Pano tripod heads. That's exactly what they do!
