BestOfferBuy
- Joined
- May 5, 2011
- Messages
- 589
- Reaction score
- 1
Price: $13.00
- DSLRKIT AC-04B 4 channels FM (Transmitter + Receiver) Set Wireless Flash Trigger for Studio
- extra receivers if you need:
the transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand, - eg.
4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A;eg.
4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).
- The brand is called DSLRKIT.
The remote trigger for studio flashes and outdoor flash is used as the controller of synchronous trigger studio flash of cameras. It consists of a signal - sender and a receiver trigger and works by means of the frequency modulation wireless remote control.
- The signal transmitter adopts the advanced circuit and components, and can transmit the coded FM wireless signa. The circuit of the transmitter has the function of standby and hibernation, thus it has low power consumption; the products can work under the standby mode for more than one year with only one battery; continuously trigger for thirty thousand times. the trigger current is only 0.01MA, which will definitely cause no damage to the flash contact of the camera. The transmitter is applicable to the traditional or digital camera with hot shoe or PC controlling interface.
- Receiver trigger adopts dry battery for power supply, which is safe, energy-saving, and convenient. The product adopts micro-computer for controlling the decoding, Which has superior anti-interference capability; sensitive reaction speed, the highest synchronous speed can reach 1/500 sec.
- Transmitter Receiver Power Source: 23A AC 100-230V
- Outdoor operating distance (open area): >30M
- Indoor operating distance: >10M
- Frequency Channel: 4
- Operating Frequency: 433Mhz
- Outdoor Synchronous Speed (open area): Max 1/500sec
- Indoor Synchronous Speed: Max 1/250sec
Make sure the channel selector of both transmitter and receiver at same position
Insert the receiver's trigger output plug into your flash's jack
Press the test button on your transmitter. The studio light should now flash
Insert the transmitter's hot shoe socket into your camera's hot shoe jack
(if your camera does not have a hot shoe use a PC sync cord and insert into the socket)
You should now be ready to start shooting
- Weight: 35 g
Buy DSLRKIT 4 Channel Wireless Studio Flash Trigger AC-04 Here
New Products:
LOMO 3-Lens Robot 35mm Film Camera (Black + Orange)
LOMO 3-Lens Robot 35mm Film Camera (White + Green)
LOMO 3-Lens Robot 35mm Film Camera (White + Pink)
Shoot MC-30 Remote Shutter Releases for Nikon D4 / D3 / D3S + More
Shoot RS-60E3 Remote Shutter Releases for Canon PowerShot G1X +More
Shoot DMW-RS1 Remote Shutter Releases for Panasonic DMC-FZ50 + More
Shoot TC-DC2 1.0" LCD Camera Timer Remote Cord for Nikon D90 + More
camera accessories, camera bags, camera lens, digital camera accessories, camera filters
