Jeff Canes
- Joined
- May 19, 2003
- Messages
- 6,194
- Reaction score
- 28
- Location
- Hollywood, FLA USA
- Website
- www.pbase.com
- Can others edit my Photos
- Photos OK to edit
Ektachrome IR Experiment
I shoot 2 36-rolls of his film between November and December at different location around South Florida. Processing EIR with E-6 produces false colors with higher color saturation and contrast. It can also be processed with AR-4. Also it is recommended by Kodak that you use a #12 yellow. The lab that I used for processing only does high-end drum scan and not inserted in doing low-end scans for me. So I took them to Costco, but there scans do not seem as sharp as slides to me. I need to by a film scanner.
The only changes to the color version (except one) were cropping. The B&W there converted in Elements 2 with Niks B&W filter. I did tinker with levers before converting.
Spec:
Canon EOS-1
Simga 28-70mm 2.8
#12 Yellow Filter
200 ASA
E-6 process
Processed by Chromeworks Hollywood
Scanned - Costco
5
Spec:
Canon EOS-1
Simga 28-70mm 2.8
#12 Yellow Filter
200 ASA
E-6 process
Scanned - Costco
5
