Epson USB cable. How long is too long?
Discussion in 'Beyond the Basics' started by StanNJ1, Dec 19, 2007.
  1. StanNJ1
    StanNJ1 TPF Noob!
    Oct 26, 2006
    Hello. I just purchased a beautiful Epson 2400 printer but because of it's size will have to be located far away from my computer. The cable would have to be around 30 feet long. Is this too long? If so any other recommendations? Your help will be appreciated.
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    There's no such thing as too long when it comes to computer cables!
    Are you worried about how the electricity is going to conduct through 30 feet of cable? Don't worry about it, if it wouldn't do it, the cable wouldn't be made. The cable could be a mile long and it would still work fine.
  3. leaving0hio
    leaving0hio TPF Noob!
    Jun 24, 2007
    129
    East-Central Indiana
    It looks like you may be able to stretch it if you use a USB hub...but take it with a grain of salt.....
    Quoting from USB.org:
    Q1: How long of a cable can I use to connect my device?
    A1: In practice, the USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches).
    Q2: Why can't I use a cable longer than 3 or 5m?
    A2: USB's electrical design doesn't allow it. When USB was designed, a decision was made to handle the propagation of electromagnetic fields on USB data lines in a way that limited the maximum length of a USB cable to something in the range of 4m. This method has a number of advantages and, since USB is intended for a desktop environment, the range limitations were deemed acceptable. If you're familiar with transmission line theory and want more detail on this topic, take a look at the USB signals section of the developers FAQ.
    Q3: How far away from a PC can I put a USB device?
    A3: With the maximum of 5 hubs connected with 5m cables and a 5m cable going to your full speed device, this will give you 30m of cable (see section 7.1.19 for details). With a low speed device, you will be able to get a range up to 27m, depending on how long the device's cable is. With a straightforward cable route, you will probably be able to reach out 25m or so from the PC.
  4. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    What about Ethernet cables? I believe that these don't have the same restriction for length that USB cables do. You could then use an adaptor like THIS.
  5. salexander867
    salexander867 TPF Noob!
    Nov 14, 2007
    48
    Not true
  6. luis_relampago
    luis_relampago TPF Noob!
    Oct 29, 2007
    54
    Houston
  7. forceofnature
    forceofnature TPF Noob!
    Nov 14, 2007
    87
    Maryland
    agreed, there are specs to every standard.
  8. TLI
    TLI TPF Noob!
    Mar 11, 2007
    125
    Plymouth State University
    Ethernet would be fine if it supported it, which it doesnt. a good fix is a usb printer hub. its cheaper than wireless and can work at more than twice the speed (up to almost 5 times since USB 2.0 is @ 480Mbps)
    not true, unless boosted USB is only 1.5V. if you ever look at a long stretch of home electrical wiring on poles there are transformers every so often, this is to bump up the voltage since it drops due to an imperfect world. if they didnt do this the 220V (amperage is a factor too though not as much with the USB) that enters your home at the the electrical panel would be less than half that, and then things wouldnt work.
  9. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Very untrue. A mile long USB cable would not work.
    The spec for 100BaseT is 100 meters.
    Both of these standards can be extended through the use of hubs, repeaters, switches, bridges, routers or another host acting as one of those other devices.
  10. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    oops.
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    The USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches).
    USB's electrical design doesn't allow it to extend past this length. When USB was designed, a decision was made to handle the propagation of electromagnetic fields on USB data lines in a way that limited the maximum length of a USB cable to something in the range of 4m. This method has a number of advantages and, since USB is intended for a desktop environment, the range limitations were deemed acceptable.
  12. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    I thought the 3rd post put this to bed quite nicely.
    -S
30 ft epson usb cord
can your printer cord be too long
how long can a usb cable be and still work
how long can a usb cable be?
how long can a usb cable to use with an scanner
how long can a usb printer cable be
how long can my usb printer cable be
long printer cable ok?
maximum length of usb cable for printer
usb cable too long
