Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,139
- Reaction score
- 3,701
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
I do a lot of panoramas, and the only way they work is to NOT MOVE THE CAMERA'S POSITION. A change in perspective will destroy any chance of building a panoramic scene. Pan the camera across for wide panorama, tilt the camera for vertical panorama, but do not move the camera or change the zoom or focus. You can't make a panorama that works if you shoot a building face, then walk 30 feet down the street and shoot the next building. The perspectives will never match up.
That said, it should be obvious that a panorama of something too close won't work well, as the widest areas will be severely distorted. My usual limit is four or five frames, with about a third of a frame overlap, and I build them in Photoshop, which does a rather good job with it. This picture is four frames across, with about a third of a frame overlap from one frame to the next. No calculations (other than what Photoshop does,) but no changes to the camera between frames. You can't... change... anything.
As for a button to lock focus, you're describing back-button focus. Some cameras have a dedicated button, some have a button that can be set for that in the menus.
I also like to do panoramas and sometimes it's pretty hard to not move at least a little. Like the 4 frame shot below of the bridge at Lansing Iowa. Not only was the canoe moving but so was the river.
