DScience
- Joined
- Apr 12, 2009
- Messages
- 1,513
- Reaction score
- 122
- Location
- Denver, CO
- Can others edit my Photos
- Photos NOT OK to edit
Flow with the Obstacle by Daniel Sanculi, on Flickr
Not bad. I like that most of the image is in focus, even into the background. I think the exposure is a bit long as there is no "flow" detail in the foreground water and it is slightly blown out. I shoot a lot of these types of images, so if you tell me you exposure details, maybe I can make a suggestion. Also, if you have a polarizer, it works quite well to reduce the "glare" off the flowing water and may help with the slight over exposure.
WesternGuy
Put the polarizer on first, then the 10 stop.
Which 10 stop system are you using? I use the Lee system and have no problems with their polarizer. You could drop to a 6 stop ND (screw-on), if you have one, and keep everything else the same and see what happens with a polarizer. I am a great believer in experimenting, so in a situation like yours here, I would probably have taken at least 5 or more images at different settings to try and get what I wanted.Not bad. I like that most of the image is in focus, even into the background. I think the exposure is a bit long as there is no "flow" detail in the foreground water and it is slightly blown out. I shoot a lot of these types of images, so if you tell me you exposure details, maybe I can make a suggestion. Also, if you have a polarizer, it works quite well to reduce the "glare" off the flowing water and may help with the slight over exposure.
WesternGuy
Thanks for the feedback!
I'm just starting with landscape photography, thus I appreciate the comments. I was using a 10 stop ND filter, and thus couldn't put a polarizer on the front, but I do use them for other images.
F/14, 6 seconds, ISO 50
BTW, I looked at your flickr and only saw one long exposure of water. Do you have any others you'd like to share?
Beautiful image. Just one man's opinion, but one man who has been right before . . .Flow with the Obstacle by Daniel Sanculi, on Flickr
WesternGuy
Your timing of 6 seconds seems a little long, even with a 10 stop ND. Personally I would experiment with 3 seconds and see if that helps "flow lines" show up.
I probably do have other "flowing waters images", I just haven't put them on my Flickr site. I know I have a bunch from the Columbia River Gorge that I shot a few years ago. If I can find them, I will put them up in a separate album and let you know.
You said that you are just starting out in landscape photography, so, if I can suggest, if you haven't done it already, find one, two or three landscape photographers whose work you admire and study their works. A couple of my favourites are Alain Briot and Guy Tal. Subscribe to their newsletters and follow their blogs. You would be surprised how much you can learn or maybe you wouldn't(?).
WesternGuy
WesternGuy
Just a thought, but you could set your polorizer first and mark the outer ring for realignment with something easy to remove such as colored pencil. Then apply your ND filter and realign the polorizer with the marks.Put the polarizer on first, then the 10 stop.
But it's a circular polarizer. Thus if I put it on, then the 10 stop ND, I won't know if the polarizer is rotated in the correct orientation (because you can't see anything through the 10 stop filter). And screwing the 10 stop onto the polarizer will surely rotate the polarizer.
Any suggestions? The only thing i've thought of is to invest in a LEE set up.
