03civicdx
- Joined
- Jun 13, 2009
- Messages
- 109
- Reaction score
- 0
- Location
- north carolina
- Can others edit my Photos
- Photos OK to edit
Shot with Canon XSi with sigma 28-80mm macro.
# 3 is not quite centered but close lol.... so people even use the rule of thirds in macro pic?:scratch:#1) The name across the center kills it. The image is out of focus, and centered. It could be improved by cropping out the dead flower in the bottom right corner.
#2) The petals are over exposed and the flower is centered. The image could be improved by cropping just above the hot spots on the petals, and from the right side of the frame, which would get rid of the little distracting thing in the upper right corner.
#3) This shot is probably the best from this set, but again it is centered. It's ok to move the petals around to cover up things like the green part of the plant that is protruding through them.
#4) Same as the others with the centered subject. The flowers look over saturated (as red objects often do), and you might have over sharpened the image,.. there is some kind of haloing going on.
