FS: Avenon 21mm f/2.8 Super Wide Lens Excellent Condition
bwc1983
This is a used lens and viewfinder in Excellent ++ condition. Barely used. But an excellent lents for super-wide landscapes or urban photography. No fog or separation in the lens. A perfect, unique and fun lens to shoot. $585 shipped.
The Avenon 21mm f2.8 has 8 elements in 6 groups, f/stops from 2.8 to 22, 58mm filter size, 6 aperture blades, 7 1/2 oz, 66mm overall diameter x 48mm overall length (35mm mounted on camera), weight 220g. Lens, metal shade, front and rear caps, 21mm metal brightline viewfinder, standard-type LTM to M adapter (adapter is keyed for 35/135 frames on standard M-mount cameras). Note: will bring up 28mm framelines on Minolta CLE. Accepts 58mm filters of standard depth (4mm).
Compatible with: Leica -- All M39 and M bodies, Minolta CLE, Konica Hexar RF, Cosina Voigtlander Bessa - R, R2, R3, R4, T, L. (with appropriate adapters)
The finder is bright and quite large with a 39mm diameter. It has a projected bright line and parallax correction marks in the finder. However, the corners are slightly obstructed for glass wearers. While it sounds French, this is actually a modern rangefinder coupled, multi-coated Japanese optic made by Y.K. Optical, a small company based in Yokohama, Japan. No box or booklets included in the sale. Will include 58 mm UV filter.
BUMP $500 plus shipping
