Up for sale is this Flir T620 Thermal 640x480 thermographic Camera in superb condition, ready to be used for work.
The new Flir T 620 is a revolutionary IR camera that provides the best thermal resolution in the business for professional thermographers wishing to carry out comprehensive thermal maintenance and inspection of electrical and mechanical systems. This infrared camera will ensure that these systems are operating correctly, safely and efficiently. With the new Wi Fi connectivity, detailed thermal reports can be quickly and accurately created on-site and are simple to share with the relevant clients and colleagues. The T620 provides the most innovative way to efficiently capture, analyse and share thermal information.
The T620 is a feature rich infrared camera that includes the ground-breaking Wi-Fi Connectivity first seen in the new E-series of cameras. This industry first technology allows the T620 imager to link with mobile devices such as an Apple iPad, iPhone or iPod Touch to speed up analysis, reporting and sharing. Simply download the FLIRViewer App from the Apple Store and you're ready to import thermal images directly from your T-Series camera. Once transferred, you have the option to fine tune your images by adding further measurement spots, adjusting span and level and changing colour palettes to create comprehensive reports that can then be quickly shared via email. The Wi-Fi capability of the Flir T-series will have a big impact on your efficiency, productivity and credibility.
The fantastic new FLIR T620 Thermal Imager combines the comfortable, ergonomic design of the Flir T-series with the incredible thermal imaging capabilites of the Flir P-series. The 640 x 480 pixel detector resolution provides professional thermographers with the highest thermal resolution and sensitivity on the market for high accuracy temperature measurements. This high resolution combined with the dual 5 megapixel digital cameras allow the T620 to offer the sharpest visible light and thermal images required for the comprehensive documentation of a system's thermal condition. The Flir T620 has the flexible ergonomics of the T-series, with a unique rotating optical block that offers 120° range of motion for increased comfort and mobility when acquiring infra red pictures.
The T620 also now features FLIR MSX Technology to easier find and identify issues. FLIR MSX Multi-Spectral Dynamic Imaging extracts high-contrast highlights from the camera’s image and then uses FLIRs patented technology to superimpose the enhanced details on the infrared image. This provides enhanced clarity on thermal imagery, even incorporating key details such as numbers, labels and structural features
The Ultimate in professional thermal imaging cameras:
FLIR T620 Includes
1 x Hard Case
1 x 8GB SD Card
1 User Manual
1 x 2 Bay Charger
2 x Batteries
1 x HDMI Cable
1 x Research IR Sd Software
1 x Tripod Adapter
1 x 25 Degree Lens
Using FLIR's MeterLink enabled test and measurement devices in conjunction with the Flir 620 you can wirelessly transmit critical data from these devices directly to your IR imager and use these readings to annotate your thermal images to further support your findings and help to quantify the severity of electrical problem.
Asking: USD$22,550.00 Reasonable offers will not be refused, so please make me an offer.
If you are interested, please contact me via PM or email.
keyh503 at gmail dot com
I will get back to you asap!
Thanks!
FLIR T620 Includes
1 x Hard Case
1 x 8GB SD Card
1 User Manual
1 x 2 Bay Charger
2 x Batteries
1 x HDMI Cable
1 x Tripod Adapter
1 x 25 Degree Lens
Thanks!
