HDR's? Whats the point?
Discussion in 'Photography Beginners' Forum' started by seward93, Feb 22, 2009.
  1. seward93
    seward93 TPF Noob!
    Feb 17, 2009
    145
    St John's, NL
    What exactly is the point of HDR's?
    I've seen some HDR threads today and I really don't understand what you accomplish from putting multiple pictures together, and I really don't understand how they do it!
    Thanks, jordan
  2. Mgw189
    Mgw189 TPF Noob!
    Dec 31, 2008
    838
    Binghamton, NY
    To put it simpily take three shots one under exposed one exposed correctly and one over exposed. The purpose being to get more properly exposed areas in a photo. In the under exposed you will your highlights should be exposed correctly. In the over exposed shot you will get details in the darker areas.
  3. mosu84
    mosu84 TPF Noob!
    Dec 15, 2008
    185
    Boston
  4. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    Well, a quick wikipedia search would probably answer this question (or a search on this forum for that matter)
    but basically, an HDR allows you to utilize a much larger dynamic range than a camera can record in a single image. By producing an under exposed, a properly exposed, and an over exposed photo you will have more detail in the shadows, and in the highlights of an image. People often produce quite a dramatic change in the image by doing this.
    This is often done with software specifically for HDR's such as photomatix.
  5. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
  6. seward93
    seward93 TPF Noob!
    Feb 17, 2009
    145
    St John's, NL
    Alright, thanks everyone for the quick answers.
    Another question, how exactly would you "under expose" and "over expose" ?
    Sorry about all the questions, but everyone has to start somewhere!
  7. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    well, when you get your xs, you can do it by setting the exposure bracketing.
    Read the camera manual when you get it, test it out and it will make much more sense than us explaining it to you now.
  8. seward93
    seward93 TPF Noob!
    Feb 17, 2009
    145
    St John's, NL
    Alright.
    I'm guessing it would be rather hard with my PS fujifilm a500 right now?
  9. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    no probably not... I would look for an exposure compensation, or manual mode on your camera. And then under expose it (I.E. use settings that will give less light than what it says you need) and over expose one ( using settings that will give more light than what it says you need) and do one the same as what it says.
    generally it's best to do this all on a tripod so the camera stays in the same position for all three shots.
  10. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    I just looked it up, and it says the fuji a500 has manual mode which consists of white balance and EV. You are looking for the EV, changing that up and down will over and under expose the photos.
  11. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    HDR is largely for lazy noobs and it usually ends up looking radioactive anyway. I prefer to be in the right place at the right time.
  12. mosu84
    mosu84 TPF Noob!
    Dec 15, 2008
    185
    Boston
    So you never have an image that has a dynamic range larger than your camera can handle? Or do you use exposure blends or what?
