Here's how to clean your sensor
Discussion in 'Digital Discussion & Q&A' started by fadingaway1986, Mar 14, 2006.
  1. fadingaway1986
    fadingaway1986 I Burn Easily :(
    Feb 4, 2004
    1,449
    9
    Queensland, Australia
    Last week, after being asked how to clean the sensor in a DSLR - our teacher went out to search for the answer, she returned and told us, that you can get an attachment for your vaccum cleaner that will suck the dust out!
    Sooo. There you go. Should be able to get them at camera shops I assume
  2. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    are you serious?
  3. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    I suppose if it limited the flow of air enough. But it might damage your vacuum?
    It would just have to have a mount on the front that is the same as the camera. Could work well, can't see much of a market for it though.
  4. fadingaway1986
    Feb 4, 2004
    1,449
    9
    Well You know how you get the attachments for doing the corners in your house - I am picturing it to be something like that.
    Worth looking into anyway
  5. spiky_simon
    spiky_simon TPF Noob!
    Mar 9, 2006
    63
    Melbourne, Australia
    I'd be interested in seeing this :wink:
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    NO! NO! NO! NO!
    The vacuum is one of the dustiest things in your house. Keep it far, far away from you cameras.
    If you want to use a vacuum, you need to buy one that will only be used for your camera gear, and keep it in a plastic bag when not in use. I keep a small vacuum in my darkroom for cleaning sheet film holders, but I wouldn't let it near my digital camera.
    I've been using a cheap foot powered, air pump (it was $13) to blow off my sensor. I only use it for my DSLR, and keep it as dust free as possible.
  7. fadingaway1986
    Feb 4, 2004
    1,449
    9
    well there you go - I would believe you anyday, ksmattfish :)
  8. thebeginning
    Jan 10, 2005
    3,795
    30
    Texas
    does that work well matt?
  9. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I use a blow bulb, it works nice
  10. clarinetJWD
    clarinetJWD The Naked Spammer Staff Member
    May 11, 2005
    5,787
    97
    Houston, TX
    I use copperhill imaging's sensor cleaning kit. WOrks like a charm, but takes a bit o bravery...actually requires wiping the sensor.
