How to fix wrong WB
Discussion in 'Photography Beginners' Forum' started by hartz, Aug 26, 2010.
  1. hartz
    hartz TPF Noob!
    Aug 23, 2010
    117
    Cape Town
    Last night I was playing arround with WB preset-ing on my new D3000. This morning as I left for work some ducks walked onto our lawn and I took a bunch of photos, forgetting to check it [The WB settings] or set a more sensible WB value.
    The photos came out nicely but with a heavy blue colour. Is there a way I can undo the WB preset?
    Thanx,
    _hartz
  2. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    open the phto with the software that came with you camera. There should be a temperature setting. Just make it warmer.
  3. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    I assume you don't work with RAW files? If you do, it is easy to change the WB in the process. When it's .jpeg-files you work with, you can do as Schwettylens suggests. If you have Photoshop, you can adjust the Colour Balance (don't know if the newer PS versions still call it that?).
  4. hartz
    hartz TPF Noob!
    Aug 23, 2010
    117
    Cape Town
    Thank you.
    I think what I want to know is: Is there an accurate way to remove the WB preset values applied by the in-camera post-processing.
    More exactly, can I get the parameters which was used to perform the WB "weighing" due to my preset (which is still "remembered" by the camera) and input these into a program to accurately undo the changes?
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    it is difficult to make these corrections with a jpeg file, easy with RAW,
    you can look at opanda.com , they have a free filter program that may help, or perhaps as has been suggested the software program that came with the camera, or another software type.
  6. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    If you shot it with RAW, the program knows exactly at what temperature the wb was shot with. Hell, you can even shoot in black and white and you can turn it back to color. IF you shot it with JPEG, you can only change the slider to cooler or warmer. There is no temperature you can plug in. I do not know if there is a way to undo the WB within the camera it self.
