Causapscal
- Joined
- Oct 11, 2016
- Messages
- 225
- Reaction score
- 71
- Can others edit my Photos
- Photos NOT OK to edit
Sony A7S II, maybe...
I really like it but it's 3000$ compared to 1400$ for the A6500, but the A7 ii is 1700, that is the other camera I am contemplating.Sony A7S II, maybe...
So I'm videoing with a 1 inch sensor on my P&S. So I could switch to manual and set shutter for 1/60, 30 frames per second and largest aperture opening. Just to decrease DOF. Then the Auto ISO would have to adjust for correct for exposure. Does this make sense? Contrast
; I believe you meant to say "increase" the settings to increase contrast. Yes?
Would 24fps be better than 30f? (Then set shutter for 1/50 rather than 1/60)??
That´s generally speaking correct. Even tough you can´t expect wonders from a 1 inch sensor I´m afraid.
But for outdoor shootings an open aperture and 1/60th (or 1/50th for 24fps - which is better in regard to film look, yes) lets quite a lot of light in. Too much to compensate with ISO only. That´s where an ND filter comes in handy. It reduces the light in order not to overexpose the footage.
Does that make sense?
And regarding contrast: it really means decreasing to get a more soft, flat look. Sounds weird, but movies usually have less contrast. That gives you a better dynamic range too and it´s easier to capture highlights as well as shadows.
And finally don´t forget about focal length. The further you zoom in, the more shallow the depth.
At what size enlargement?Pixels of the 7aS are bigger. I saw the samples and it's impressive !
I have a built in ND filter that I have to try out. Not sure what filter factor it is. Thanks for the info.
Yet again someone finds the need to wake up the sleeping dead, let this sleep man its OLDDDDDDDDDAt what size enlargement?Pixels of the 7aS are bigger. I saw the samples and it's impressive !
Sorry, I told «pixel» but I mean « photosite»
