Ilfosol S and thin negs?
Discussion in 'The Darkroom' started by kslagerman, Oct 5, 2006.
  1. kslagerman
    kslagerman TPF Noob!
    Oct 5, 2006
    6
    Sacramento, CA
    Hello, I am just starting out with the 4x5 and developing at home because the lab at school is really crowded.
    I have a decent working knowledge of the zone system and am almost positive I am exposing correctly but I am getting consistantly thin negs. I am using Ilfosol S (68-69F @ 7mins) with HP5+ 400. I am thinking there are two possibilities.. (not including the fact that I might be underexposing)
    1. I have been reading that Ilfosol is sort of a lame developer when it comes to faster films like HP5+. We use HC-110 at school and I have had MUCH better results there. Could this developer be causing the thin negs?
    or
    2. The lens on my 4x5 is rather old (has the old shutter speeds like 400, 200, 100, 50 etc etc) and I am not 100% sure that the shutter's timer is accurate. I definatley know that is bad at anything over a 1/2 sec. Maybe it is underexposing? I would tend to think that if the shutter's timer was sticking or going bad, it would slow down and over expose, rather than speed up and under expose.
    I attatched a pic to show what Im talking about. (pls ignore the fact that its fogged and wasnt loaded into the camera properly, its the only one i have on hand right now :p)
    Any thoughs?
    Thanks!
    [​IMG]
  2. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    If HC 110 provides good results, why mess around with something else?
  3. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,379
    2,840
    In the mental ward of this forum
    I would agree. Switching developers will be a lot cheaper than thinking you need to upgrade lenses. If you have gotten good results with HC-110 with your setup, go back to that. If you still have a problem, then you'll need to try something else. :)
    Welcome to TPF! I'd love to see some of your 4x5 prints.
  4. ladyphotog
    ladyphotog TPF Noob!
    Oct 4, 2006
    215
    Georgia
    Looks like a developer problem, if you still have some of the Ilfosol S developer left you could increase your temp and time. You would need to test to get the right mix. Once you use it up I would go back to the HC-110 that are are having better results with.
  5. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    hmmm.... I suppose you're shooting (metering) the same as you did when you processed your film at school. And, I suppose you're used to seeing denser negs. Could it be that this one is softer (less contrast) than you're used to seeing?
    Pete
  6. kslagerman
    Oct 5, 2006
    6
    Sacramento, CA
    good advice. When i was buying supplies for home use, I just thought i would go with the "general purpose" ilford developer for ilford film, not knowing that it would make such a difference. Im going to get a bottle of hc-110 today and see what happens. hopefully it will produce better results
    thanks to all of you.
  7. kslagerman
    Oct 5, 2006
    6
    Sacramento, CA
  8. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    If you are still monitoring your question...
    Concerning your first photograph: how far away were you from the subject, what focal length is your lens and how far was your bellows extended?
  9. Christie Photo
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    I don't think it's a concern. It looks to me like a normal focal legnth lens and not so close that he has more than a 6" draw. Good thought though. Nice to know some of us still understand this.
    Pete
  10. kslagerman
    Oct 5, 2006
    6
    Sacramento, CA
    a good thought. no significant need for reciprocity or bellows adjustment with that one. thanks again though. i think im just going to stay away from the ilfosol
  11. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    lol, yes, some of us do know about these things, all LF here. Would be curious to see the same scene under the same lighting conditions with the HC-110 for comparison. It just looks very flat over thin now that I looked at it again.
  12. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    i've also had the same problem with Ilford S Developer and Thin negs (though i was developing ilford pan f +. )
