Infared tips (hoya R72 filter)
Discussion in 'Beyond the Basics' started by 6Speed, Aug 2, 2006.
  1. 6Speed
    6Speed TPF Noob!
    Oct 31, 2003
    77
    This is probably a dumb question but...I just got a hoya r72 filter, and tried to do a few shots tonight in my apartment. I have an aquarium with 500w of light over it, and it barely shows up with a 2 minute exposure. I tried a shot in my kitchen for 3 minutes and it looks totally black. I'm assuming that this filter is only going to work in the bright daylight? :)
    Any tips for shooting with this filter??
  2. bytch_mynickname
    bytch_mynickname TPF Noob!
    Jun 4, 2006
    303
    Yes, this is a bright daylight, outdoor type filter. All I can really say is to use a tripod, make sure you set a custom white balance (using grass) and above all, don't give up. I tried and tried some more before even getting shots that looked even a little like an IR shot. Good luck.
    (I will be sure to check back to get more experienced tips and opinions, I need every bit of help I can get:blushing: )
  3. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    Bytch is on the money. IR filters are best used outdoorsÂ… And even then, composition and focus will have to be accomplished prior to the filter being attached. A tripod is an absolute necessity.
  4. fotogenik
    fotogenik TPF Noob!
    Jan 16, 2006
    345
    Louisville, Kentucky
    Aquarium lights don't normally have a lot of IR light in them. If I remember corectly they are specifically filtered to reduce IR output because it would heat up the water in the tank and encourage growth of algae.
    A quick search on an old aquarium lighting bookmark of mine yeilded this:
    Full spectrum tubes imitate, as closely as possible, natural sunlight by emitting light in every spectral range. All the different colours of visible light and a very small amount of ultraviolet is emitted. All these tubes have an output spectrum that is similar to sunlight - about as close as modern chemistry can bring us. These tubes try to imitate equatorial sunlight at noon, which has a colour temperature of around 5000K. Noonday sunlight from northern climes has a larger amount of blue in the spectrum, as has a colour temperature of 7500 Kelvin. Among them, we should note the tri-phosphor tubes which emit in the three basic bands blue, green and yellow. Since the phosphor producing the red color is the most expensive one, usually there is less red emitted from those lamps.
    Full spectrum aquarium lights are normally the reddest lights you can get for an aquarium and they emit very little red light. Other aquarium lights emit almost no red and are reffered to as "Actinic" or Actinic-blue" lights and have a distinctly bluer light.
    The Hoya R72 filter is definetly an outdoor, bright sunshiny kind of filter. Go to a graveyard on a bright day at noon, sit your camera on a tripod or rock and start snapping away, bring them home and process them for white balance and true B&W infred style or false colour infrared style and you will have something like these:
    http://picasaweb.google.com/snmphoto/infrared/
    Cheers,
  5. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Yup. IR light isn't visible, and a lot of artificial lights won't put much of it out. You can't go by the brightness of the bulb. The best source of IR light is the sun or specific IR lights, which you can use to light scenes without disturbing the subject.
  6. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Any advice on exposure times? I've read up a bit on this as well am interested in trying it out eventually. Assuming it's a clear sunny day... any type of estimates you could provide?
  7. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    if its a very bright and sunny day, i usually use a exposure time of 2.5 seconds at F8, ISO200. But its just a case of trial and error. Just shoot and see what looks best.
  8. AluminumStudios
    AluminumStudios TPF Noob!
    Oct 20, 2005
    99
    Pennsylvania
    Water absorbs infrared and looks like tea or coffee to an IR modified camera. I'm sorry, but you're not gonna get pictures of your fish in IR :p
    Here's a freaky photo I did of my face in a normal white bath tub full of crystal clear water
    http://static.flickr.com/49/115508042_a96faaea09_o.jpg
    If you buy 200 watt, clear lightbulbs, and aim about 3 of them at your subject you can do some indoor IR photography with a Nikon at least (I believe Canon's are a bit less sensitive. I don't know about other brands.)
  9. fotogenik
    fotogenik TPF Noob!
    Jan 16, 2006
    345
    Your Right. I had not even thought about that.
  10. MommyOf4Boys
    MommyOf4Boys TPF Noob!
    Dec 20, 2005
    2,386
    51
    Alabama - just moved here from Texas
    I have found that the best exposure time for IR shots, depending on the brightness of the sunny area or the shaded area, is anything from 1/13 and 1/8 in sunny areas to around 1 sec and 2 sec for shaded areas. Play around with the settings and take several shots with each setting to see what looks best after post processing.
  11. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    I'v found the best time to be around 4-6 sec on a bright day..... but then i shoot at f22. ;)
  12. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    And I'm guessing you use the high F-stop because you focus, compose, add the filter and shoot? Less chance of losing focus if you have a huge DOF.
how many stops increase hoya r72 infrared
hoya r72 post processing
hoya r72 tips
ir72 filter photographs
