IR HELP NEEDED!!
Discussion in 'Beyond the Basics' started by photyo, Aug 11, 2006.
  1. photyo
    photyo TPF Noob!
    Aug 3, 2006
    11
    Everytime I take a picture with my r72 the image is red no matter if i set my white balance to the green grass or not! i tried to follow these insturctions http://home.comcast.net/~vicpinto/IRPostProcessTutorial-1.htm but they are worthless because i can not even get close to his colors someone please help! thanks
  2. joyride
    joyride TPF Noob!
    Dec 21, 2005
    361
    Kalamazoo
  3. photyo
    photyo TPF Noob!
    Aug 3, 2006
    11
    thanks but that just ended up turing my whole image blue! haha
  4. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    sounds like the custom white balance hasn't worked to me..... What camera do you have?........ are they all red in the camera preview screen?
  5. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    If I hear anyone say that digital IR is as good as or better than real IR, I'm going to run around the city breaking every DSLR I see.
    Interesting conversation though....carry on.
  6. photyo
    photyo TPF Noob!
    Aug 3, 2006
    11
    I have a nikon d70s and yes they are all red in the camera preview screen
  7. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    um ok..... digital IR can be as good as as film (if you mean film by saying 'real IR')..... you best get smashing :lol:
    Hmmm.... they should be blueish/brown in the preview screen..... try retaking the white balence..... it took a few attempts for me to get a good one.....
    Make sure its taken from a sunny area of grass and that the camera excepts it as a custom WB. ;)
  8. fotogenik
    fotogenik TPF Noob!
    Jan 16, 2006
    345
    Louisville, Kentucky
    ok, This is a long winded response, be prepared......
    Here is the deal. 1 Film IR is better than digital IR because it does capture more detail and it is more sensitive to the IR spectrum.
    However, to the layperson (not a photographer), a digital image and a film image held up next to each other, they will not be able to see the difference without it being pointed out to them.
    End of that argument.
    The shots with digital camera will come out red out of the camera. Best thing to do is shoot in raw and apply a software custom white balance. That is MY OPINION...don't argue with it, it is not a statement of fact, it is the best method I have found. Other ways are to shoot a custom white balance and use that for all your shots, however do to the movement of the sun, refraction of the atomsphere and about a billion other factors the white balance will need to be reshot throughout a day of shooting as the color of the light from the sun will change dramatically throughout the day.
    I use a software white balance that I set in my camera raw software during processing, YMMV, Use your own best method.
    once your white balance is set in raw software then your image will look more like IR.
    I personally don't typically shoot IR in jpg mode, (ok, I have never shot IR in jpg mode) because I don't know of a way to change the white balance and therefore the shot will be red because the r72 filter I use filters everything above the red spectrum and most of visible red as well.
    Just realized you stated you had a D70s. Shoot in RAW, you will be much happier with the results. They will be red coming out of the camera. You have to process them on your computer before they will look like film IR.
    The D50 and the D70s both use the exact same sensor. with Digital IR you have the option of processing the photo to B&W IR or what is refferred to as False Colour IR. I personally prefer false colour, as does a friend of mine whose gallery is here.
    Cheers,
  9. photyo
    photyo TPF Noob!
    Aug 3, 2006
    11
    OK its still not working Iv'e tried to use custom green wb's like 20 times and they still all come out blood red, any other suggestions?
  10. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    What program do you use to adjust the white balance in RAW photos? I have Raw Essentials (I think that's the name... I could be off though) and it gives an eyedropper to adjust the white balance. I'm guessing it figures the white balance by me clicking on 50% grey but I'm totally guessing.
    Could you give some more info on how to figure out what the white balance should be when editing in software? Thanks.
  11. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yes, in Rawshooter Essentials..... you select the custom white balance tool (the wb eyedropper).... and click on any part of green grass or tree area.
    Thats basically it..... you should now have a blue/brown image which you should export as a tiff......
    Once in ps..... you can then choose to adjust the levels/contrast as it is..... or if you want to make the sky blue again, (often known as IR false colour) you can swap the colour channels...... here's a link which can help you do this.....
    photyo, if you cant get the custom WB to work, just shoot with auto WB..... then use the steps i'v discribed above in your RAW converter software..... but you cant use Photoshops own RAW converter because it has problems with the temperature gauge....... try a free RAW converter or Nikons own converter.
  12. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I prefer setting the WB with raw software, as mentioned above. If all else fails, convert to black and white.
