Keeping it Simple: a "portrait"
Discussion in 'Graphics Programs and Photo Gallery' started by e_, Jul 12, 2003.
  1. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...... itinerant ..........
    ...over recent days - in postings about "Learning to take Photos" and "How to take 'Star' Photos" - mrsid & i have highjacked the threads with discussions on learning the basics and keeping it simple
    Not all will agree, but i believe the best design solutions are simple and direct. This carries over into my photography and achieving "the shot"
    For beginners, the language of photography is arcane, often complicated, but the principals (despite their fancy jargon) are simple; don't be discouraged by the journalese
    The situation is not helped by some writers, teachers and instruction manuals complicating matters unnecessarily (and i may well be at fault here, too, at times) with highly convoluted solutions to problems that may be resolved very simply
    This thread provides an example from "professionals" (a straight forward "bread & butter" portrait for any commercial photographer) with directions that are downright scary!
    To illustrate the point i've been trying to make with mrsid, i also offer a *simple* method which (imho) will deliver a better result than that shown ... and achievable with nothing more than a manual camera and flash
    Here's their portrait:
    [​IMG]
    ...Copyright - webphotoschool.com/Ben Clay, Ross McCord & Gene Kester
    Here's the directions from WEB PHOTO SCHOOL
    http://www.webphotoschool.com/bhphotovideo/Lessons/AngelaOutside[BH]/index.html
    Webphotoschool.com are to be commended for offering this free Site - but one needs a small sized truck just to carry their required equipment and, technically, the image is weak in my opinion with too much light on the face and unnatural lighting affects on the models hair
    Here's my solution:
    1. Equipment - camera, flash & hand held meter
    2. Position model in front of a lemon tree (they make great backdrops to match that shown) with her back to the sun to create rim light affect on hair
    3. Take ambient reading off the sun (dome behind models head, aimed at light source)
    4. Using the sunny-16 rule and 100 ISO/ASA film, let's say the reading is f-16/125
    5. Set aperture on camera to f11/125 - this will overexpose the rim light by +1 stop and create a halo affect as shown (but even better)
    6. Set flash on "A" and select f-8 as a fill flash - this will provide a natural looking lighting ratio between the hair and face (use a diffuser dome over flash head, or even just a piece of tissue paper)
    7. Compose shot - ensure there is no flare into lens from sun - then shoot
    8. For different lighting affects, you might wish to bracket a few more shots
    Done!
    If you don't have a flash - simply use a large piece of white cardboard (in-lieu) to reflect light back onto the models face. Meter carefully to achieve the right ratio
    Some photographers actually prefer reflectors to flash in this situation
    The choice is yours
    Have fun!
    e_
    P.S. yep - far too much time of me hands!
  2. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    e_ , Great post!
    Like most others here I'm astounded by how simple you make all this stuff sound.
    Brava!
    Jim
  3. MDowdey
    MDowdey Guest
    great work e_!!!! exactly what i needed, i have a job coming up to do some portraits!
    md
  4. Geronimo
    Geronimo No longer a newbie, moving up!
    Jun 8, 2003
    1,329
    Next to the point of no return.
    Thanks for the post. I hate taking portraits personally but your post helped me learn a few things.
  5. Dew
    Dew TPF Noob!
    Jun 27, 2003
    1,688
    thanks for the info ... that portrait there, doesnt have my signature :lol:
  6. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Great post e_
    Now I suppose I will need a flash that I can set the power to achieve this. All I have is a vivitar that has green A and red. It has a table on the back to set the right aperature depending on distance to the subject.
  7. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...thank you, everyone, for the feedback and kind words
    Much appreciated!
    Voodoocat : you have just hijacked my "Keep it Simple" thread. LOL ;)
    Quote..."Now I suppose I will need a flash that I can set the power to achieve this"
    * The short answer is - "yes, you will"
    * The long answer is - "no, you won't"
    Confused (?) Well, hang about - it gets worse
    There is a "theoretical" work around you may wish to try but it's counterintuitive and causes confusion, even for most of the pros'
    Let's use the readings in our example, camera on f11/125 and a required flash setting of f-8 to provide fill light
    For the example, let's say your flash only allows for an "A" setting of f-11 (the closest available option to our required target of f-8 )
    The "theoretical" work around fools your flash into providing an output which underexposes that flash setting by one f-stop, effectively providing f-8
    Here's how:
    In the example, we are using 100 ISO/ASA film which has been dialled into both the camera and flash
    To lower the flash output by one stop (f-11 down to f-8 ) we simply "increase" the ISO/ASA rating on the flash from 100 to 200, which is a difference of (less) 1 f-stop
    Don't alter the ISO/ASA on camera!
    To increase the flash output by one stop (let's say your flash only provides for f5.6 and we require f-8 ) we simply "decrease" the ISO/ASA rating on the flash from 100 to 50, which is a difference of (plus) 1 f-stop
    You should note that this is a "theoretical" work around. You will need test it for yourself on your own system and your mileage may vary. Personally, and depending on the flash unit, i have had mixed results in the past
    With regards the chart provided on your flash - that is a ready reference for use with the "M" setting. Most manufacturers overstate their system's capabilities in this regards ... and all flash units should be tested by the user to establish an accurate guide
    Hope this is of some assistance
    Cheers!
    e_
  8. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    * EDIT: (ooops...double post)
    :oops:
    e_
  9. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    e_
    Thanks for all the great info! It's nice to know that it's possible to achieve "pro" results without having to shell out for mountains of pro gear.
    (Not that I wouldn't love to have the pro gear, but my wife seems to think that food, shelter and clothes for her and the kids is more important than my photography equipment !!!! :wink: )
  10. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    You can set the power on any flash by changing it's distance to the subject. This may mean you have to use the flash off camera.
  11. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Most of the "Masters of Photography" had to use stoneage gear that makes a Canon Rebel 2000 look like the space shuttle. Practice makes perfect.
    And your wife is wrong; photo gear IS way more important than food, shelter and clothes.
  12. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    I know that's true. I am trying to practice framing and shooting every chance I get.
    Sometimes I think the older equipment takes sharper, nicer looking pics. I really love manual equipment. Just bought a manual Canon on eBay. :heart:
