Lens Reccomendation Request
Discussion in 'Photography Equipment & Products' started by ZyCzech, Jul 11, 2007.
  1. ZyCzech
    ZyCzech TPF Noob!
    Jul 11, 2007
    15
    Hey Everyone.
    I'm new to this forum and came here for help in purchasing the right camera lens. I searched the forums and did not find a topic that would answer my question.
    First off, I have a Canon 10d.
    I need to buy a multipurpose lens somewhere in the range of 55(or less)-200mm for hopefully under 500$.
    I already have a Tamron 19-35mm lens, so I am looking for one that would pick up were my Tamron leaves off all the way to 200 or so.
    So far the likely candidates seem to be the Canon EF 28-200 USM, the Sigma 18-200 DC, or the Tamron equivalent of the two.
    Is there one that you would recommend or one that I should definitely NOT purchase?
    I'm leaning towards the Canon...don't know if that is wise.
    -ZyCzech
  2. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Firstly, I have had no experience with the two lenses you are looking at. However, I have been unable to find a single lens that I would at least be happy with that covers that range and price point. I had to pick up two lenses to cover that range since I really put an emphasis on image quality. I used the Canon EF 70-200 f/4 L until I recently upgraded to the f/2.8 model. It is an excellent lens and is really sharp. Perfect for nature photog and can be had for about $550. Still leaves you that gap between your current lens though. But a Canon EF 50 f/1.8 can fill it in. Hope that helps.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Welcome to the forum.
    I don't know much about the 50-200 lenses but I agree with the post above. The Canon 70-200 lenses are some of the best zoom lenses made. There are four options;
    70-200 F4 L
    70-200 F4 L IS
    70-200 F2.8 L
    70-200 F2.8 L IS
    The first being the least expensive and the last being the most expensive (but most desirable).
    There is also the Sigma 70-200 F2.8 which should be about as much as the Canon F4 version.
  4. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    2.8 L IS -- Any lens that says that on it HAS to be great.
  5. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    ZyCzech.... the Canon 28-200 lens you are mentioning is a very so-so consumer grade lens. You get the range, but not the IQ. It will give you 'buyers remorse' in 30 days. The micro drive AF is really slooow.
    I have a couple of 28-135's that do quite well. Takes a tweak or two in PS but they paid for my better lenses in sold prints.
    As Big Mike mentioned....the 70-200 series is a big step up (in the right direction). You lose on the wide end of course. I have a couple of the f2.8's with IS and they are worth every penny spent.
    Even with your older 10D, you should see improved performance.
