Macro Lens Recommendation
Discussion in 'Photography Beginners' Forum' started by dEARlEADER, Apr 20, 2008.
  1. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    I'm a little tapped out after buying D60 18-200 and all the other swag that goes with it...
    but I really wanna do some macro stuff...
    can anyone recommend a decent lens old or new that will work with my D60?
    i really don't care if it doesn't have autofocus... and if i had to.... i could live without metering....
    thanks...
  2. N'Kolor
    N'Kolor TPF Noob!
    Oct 21, 2007
    342
    Orlando, FL
    Since you are Nikon shooter, I wouldn't worry about getting a Macro lens...you should look into a Micro lens.:lol:
  3. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    okay whatever..... can someone please recommend a MICRO lens??
  4. Samriel
    Samriel TPF Noob!
    Nov 30, 2007
    325
    Fukuoka, Japan
    The Tokina 100mm Macro is very good lens for the money ($350) if you don't mind shooting RAW (can have some CA problems which are easily solved in PP). I really like the good build quality.
    More or less in the same class ($400~$450) are the Tamron and Sigma ~100mm Macros, just without the CA problems, but with a slightly worse build quality.
    You could find the older Nikkor 60mm Macro, it should also cost around $350-$400. All of these lenses will not AF on the D60. If you want AF, the cheapest thing might just be the new Nikkor 60mm model, with "cheapest" being around $600~$650.
  5. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    Would this be the f2.8 Pro at-x?
  6. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
  7. Samriel
    Samriel TPF Noob!
    Nov 30, 2007
    325
    Fukuoka, Japan
    Yep, that's the one.
    Photozone Review
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I use a MicroNikkor AF 105mm f/2.8 D. Great lens can be found for a bargain second hand. If you want autofocus you'll need the MicroNikkor AF-S 105mm f/2.8 G which is no where near as much a bargain!
    Shorter focal lengths than 105mm require you to get very close to the subject, closer than 35cm anyway. There's a consideration if your subject has eyes and is likely to fly away.
  9. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
  10. Stranger
    Stranger TPF Noob!
    Jul 9, 2007
    495
    i hear the 60mm 2.8 af-s is a decent lens...
    about $550 new
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    The Sigma 105mm F/2.8 macro is an excellent lens, and being a prime VERY sharp.
    I will tell you that the greater the focal length is, the further away you will be from what you want to take a macro off. This comes in VERY important when you want to shoot live subjects.
    I have a lens that at 50mm just to get a 3:1 macro shot, you have to be about a 1/2" away from it, but the 105mm lets you step back about 12 inches to get a higher magnification of a 1:1 macro.
    Today if I was still looking, I would get something like a 150mm macro.
    Make sure that whatever lens you get, it does a 1:1 macro.
