manfrotto 055xprob
Discussion in 'Photography Equipment & Products' started by canon_kid, Sep 23, 2010.
  1. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    i have one of these with a 498 rc2 head, well I just started reading about L plates and gimbal heads for the bigger lenses. I do plan a canon 100-400mm L lens in the future, but untill then the biggest lens i use is 70-300 and soon a 70-200L
    so my question is: with my tripod and head set up will i need or can i even use a L plate or need a gimbal head ?
    if not what do you suggest ?
    if so what do you suggest ?
  2. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
    What are you shooting? If you're a wildlife/bird photographer, a gimbal head would be a great addition (I wish I could afford one). Many would say that you don't need one on a 400, but I know there are times it would come in handy. It's probably overkill for your 300. They are quite expensive.
    Oh ... and with some exceptions (e.g. Wimberly Sidekick), the gimbal head REPLACES your other head. You need a rotating tripod mount collar on your lens. The Sidekick slides onto an Arca-Swiss mount on your existing head. http://www.luminous-landscape.com/reviews/accessories/wimberely_sidekick.shtml
  3. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    I use to have that exact combo when I first started and used it all the way up to the EF 300mm f/4L IS. Your lens is small and light and really does not need the support of a gimbal head. I mostly photograph wildlife/ birds and had no problems with it.
    You are fine with it unless you want the gimbal action. This allows you a more positive lock and free movement when used with the heavier lenses; i.e. EF 300mm f/2.8L IS and up. You can also set the camera up and fire it remotely or with mirror lock-up more securely with a gimbal head.
  4. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    i shoot landscaps and when i get a bigger lenses i will shoot animals
  5. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    That was exactly my sentiment! So I headed for the barn and grabbed some steel, a couple of bearings, a saw, a welder, and some paint...
    Yep, that's what I wanted it for. My 100-400 flopped over one too many times after forgetting to lock it down after freestyle shooting birds or something. The pinched fingers and thumbs were no fun either when it happened!
  6. Buckster
    Sep 14, 2009
    6,399
    2,334
    A PM request to show more info on the assembly prompted this:
    [​IMG]
    Happy to provide additional info if asked. :)
  7. soylentgreen
    Feb 27, 2007
    735
    Miami, FL
    That's really cool Buckster. I considered doing the same thing. I could not justify spending $500+ for a gimbal head so I purchased the Manfrotto 393 mount. It works just as good for a third of the price. Only knock is the lack of a positive rotating lock at the base without loosening the set screw, but I will probably add a large thumb screw to remedy that.
  8. Scatterbrained
    Scatterbrained Been spending a lot of time on here!
    Apr 19, 2010
    2,184
    1,081
    Yucca Valley, Ca
    Buckster, quite cool. I've been contemplating something like that my self as a good excuse to put my welder to work. Just one question, why not make it so it screws right to the tripod rather than to a tripod head? It just seems a little redundant is all.
  9. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    i was thinking that but who wants to keep switching heads ?
  10. Buckster
    Sep 14, 2009
    6,399
    2,334
    I figured it'd more convenient this way. I have a few extra quick release plates anyway, so it's no big deal to just leave one on it.
  11. soylentgreen
    Feb 27, 2007
    735
    Miami, FL
    Your set-up is fine for the lighter lenses, but once you factor in the weight of the larger heavier L lenses. Things get whacky. You're dealing with 10 Lbs and more worth of glass! I noticed from your video that the center of horizontal rotation is off. Something that will need to be addressed; especially if you intend to use heavier loads. My only concern is the high center of gravity. The tripod will be highly unstable with that and the weight "offset". Something to keep in mind.
    I've seen the neck of those ball-type heads snap off before under stress so be careful. There is only a screw that holds the plate onto the ball. I have a Gitzo GH3780QR as a ballhead for heavy work. I used it with a long plate for a 400 f/2.8 before getting a real gimbal head.
  12. Buckster
    Sep 14, 2009
    6,399
    2,334
    The center of horizontal rotation was corrected by the time I got the second vid shot.
    This was only built to address my biggest lens. If I get the bucks to get a bigger lens like you're talking about, I'll invest in a serious gimbal mount for it. :thumbup: :)
best head for 055xprob
best head for manfrotto 055xprob
best manfrotto head for 055xprob
gimbal head bearings
is the manfrotto 498rc2 l plate
manfrotto 055xprob best head
manfrotto 055xprob bird photography
manfrotto forum
manfrotto forums
manfrotto miami
