Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,139
- Reaction score
- 3,702
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
Joe,You could lower the EC another stop or so. Maybe it would be better to slow the shutter by one stop or raise the ISO one stop. You could also use the RAW image that would give you more play with the shadow slider. A lot depends on the capability of your camera's DR.
If flash is not an option, you could have added more ambient light, possibly the best solution.
That wasn't possible -- all the interior lights were on. I wasn't comfortable with a slower shutter speed. And in that situation you would have raised the camera ISO. That's your exposure triangle methodology. And in the real world raising the ISO would have reduced DR -- that's what it does. You would have ISO clipped the information out the window with the DR reduction that came from raising the ISO.
So here's a real world example of how applying an understanding of the way the camera works allowed me to take a photo that you would have failed to get if you raised the ISO.
Because I didn't raise the ISO I retained the full DR of the sensor and I was able to keep the real world data that you see out the window in my finished photo. And that's a real world example of how you can take a better photo when you understand how the hardware works and can think clearly about it. I got a real world better photo by ignoring the triangle.
Joe
This now prompted a thought. I know there is the whole concept of expose to right. As in better to be overexposed by a stop than underexposed.
How does ISO come into play, or does it not?
Tim
Sent from my SM-J737T using Tapatalk
Great question and another can of worms. The term ETTR is unfortunately troll chum so I'm not going to use it. The pertinent term here we want to use is SNR -- the ratio of signal to noise. With digital we get a straight linear response here: more exposure = better SNR. There's absolutely no downside to that except the pragmatic requirements of taking the photos. It's the age old compromise. We're indoors and the light is dim and we don't want to use flash or a tripod and as a result to hand-hold the camera we have to reduce signal. Our hardware is so bleep bleep good now that we can get excellent quality photos with only 1/10 of the signal our sensors are otherwise capable of. Go back and look at that ISO 12K image I posted from my XT-2. Pragmatically I will tell my students that if maintaining a specific shutter speed is the critical factor then set and lock that shutter speed and put the camera on auto ISO. They complain that they were taught to never use auto ISO. Always try to keep the ISO as low as possible is what they were taught. I cuss and tell them to get the bleep photo! Just wanted to say that to maintain perspective.
So SNR is exposure. And here it really matters to say SNR is exposure the way exposure is traditionally defined. SNR is not "proper exposure" the way the ET works. Maximize SNR to the capacity of the sensor and you capture the maximum amount of data and more data is always better than less data. This one is as simple as 2 + 2 = 4.
Some caveats: Digital sensors clip hard. It's a concrete wall and there's no give if you hit it. So if maximum SNR is good, clipping the sensor is bad. In this situation our camera engineers design a hedge into the camera's exposure system. Most people think base ISO refers to the light sensitivity of the sensor -- it doesn't. Base ISO refers to the standard output brightness of the camera JPEG. All of our cameras are to a greater lesser degree designed to deliberately underexpose the sensor. Generally between 1/3 to 1 full stop. If you try to assess that for your camera and work around it you're playing a dangerous game with a concrete wall.
ISO (here I go again) is not an exposure determinant but it certainly changes the data recorded in a raw file if you raise it. Raising ISO boosts, brightens, gains, amplifies, multiplies the data that is being recorded and stored. You read about cameras having a bit depth like 12 bits or 14 bits etc. Most of our cameras now are 14 bits. 2 ^ 14 = 16,384. All our data ends up as numbers. If you record a brightness value and the number the ADC would assign to that brightness value is 300 at base ISO then if you raise the ISO a stop that number is recalculated as 600 and stored. So you see this coming now right -- if you record a highlight value and the number the ADC would assign to that highlight value at base ISO is 6,000 then if you raise the ISO a stop that number becomes 12,000 and if you raise the ISO 2 stops your highlight is clipped because 16,384 is the biggest number you can store. Raising ISO reduces DR.
Go back to the first set of photos I took with the G7 of the fish and jars. My job was to take one photo at ISO 1000 and another at ISO 125 both at the same exposure. To do that I started by calculating the ISO 1000 exposure. Knowing the ISO would be set at 1000 my job was to avoid ISO clipping but get as close as I could to recording maximum data at ISO 1000. That photo had some specular highlights -- look at the front of the jar of dried mushrooms. I allowed those speculars to clip in the ISO 1000 photo. One of the problems I had in making the two photos visually match is that those specular highlights didn't clip in the ISO 125 exposure!
Joe
