Nikkor 70-300mm 1:4-5.6G or SIGMA 70-300MM F4-5.6 DG MACRO NIKON
Discussion in 'Photography Beginners' Forum' started by AnthonyCorbo, Dec 14, 2008.
  1. AnthonyCorbo
    AnthonyCorbo TPF Noob!
    Nov 26, 2008
    60
    Which one should i get whats better? Nikon one or sigma one ( sorry for noob terms):sexywink: the nikon one is 140$ and the sigma is 130$ so price difference is minimal. Btw it's going on a d40 if that makes a difference.
  2. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    I believe neither of them will autofocus...
    Do they have AF-S?
  3. Overread
    May 1, 2008
    24,063
    4,171
    UK - England
    If you go for the sigma get the APO edition - the APO coatings on the glass will give a noticable improvment in quality over the older edition of the lens.
    Myself I would say of the two - go for the sigma. The macro feature is worth it to play around with and can be quite (very)addictive. Note that its not full macro, you won't get blindingly close insect shots, but you can get very good photography of things like the opened head of a flower or other things roughly that size.
    At this price range both are going to be softer at the long (300mm) end and both would benefit greatly from being used from a tripod setup (even a cheap tripod - the added stability really helps with these lenses)
  4. AnthonyCorbo
    Nov 26, 2008
    60
    The SIGMA 70-300MM F4-5.6 DG MACRO NIKON APO edition is $200 is it really worth the extra $70?
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Neither, get the 55-200 instead so you'll have AF.
  6. Overread
    May 1, 2008
    24,063
    4,171
    UK - England
    I would say it is yes - unless you are planning to replace the lens with better models in the near future then I would definaty say spend the extra.
    However if Reg is right (and I think he is) then not having AF is going to be a major limitation - especailly considering that DSLRs are not the easiest to manually focus on (compared to the film SLRs).
    I would check this out before purchasing and if you lose AF consider looking around for alternative lenses is possible. I can't offer any since I am not a Nikon shooter and simply don't know alternatives -- like what Sw1tch just suggested ;) :)
  7. AnthonyCorbo
    Nov 26, 2008
    60
  8. reg
    reg TPF Noob!
    May 28, 2008
    1,487
  9. AnthonyCorbo
    Nov 26, 2008
    60
    Oh,ok thanks for telling me
  10. AnthonyCorbo
    Nov 26, 2008
    60
    So the 55-200mm VR Lenses is the best choice?
  11. TUX424
    TUX424 TPF Noob!
    Aug 17, 2008
    447
    St. Louis, MO
    I would agree with that, 55-200 VR nice cheap VR nikon made lens cant really do better for the price that will AF with the D40
  12. Zach
    Zach TPF Noob!
    Dec 16, 2006
    53
    From my understanding the Sigma will AF with any Nikon.
    Sigma - Lenses
