Nikon D60 continuous shooting
Discussion in 'Photography Beginners' Forum' started by whiskydamon, Apr 1, 2009.
  1. whiskydamon
    whiskydamon TPF Noob!
    Apr 1, 2009
    Let me preface this, I am a total noob to photography and a camera that's not just point and shoot.
    I just purchased a Nikon D60 and it seems to work great in Auto, I've snapped a few and I am happy with it so far. But what I really want to do is take multiple pictures quickly and this is where my problem is.
    Remember, I don't know what I'm doing at all I'm just trying to figure out from reading the manual (I'm going to take a class asap) I set the M, set the camera to continuous mode, the shutter speed is all the way up and I click off a few pictures. Every single one of them is just a black image.
    In fact any time I even set the Camera to P or M and take a photo all I get is a black screen. This happens when I'm in a darker room or a bright room.
    Is there something wrong with my camera or is there just a setting I need to know about and change?
    Thanks for the help :)
  2. schumionbike
    schumionbike TPF Noob!
    Mar 9, 2007
    1,083
    Houston, Texas
    I can't explain everything in one post, but you should google "camera exposure" and you should get some good result to read and play with. It doesn't take that long to learn the basic of this stuff. The reason your camera won't take multiple picture in auto mode is because that flash is on. Put the flash down and you can take use the 3fps in auto mode. Hope that help, if you have more specific question, let me know.
  3. Sherman Banks
    Sherman Banks TPF Noob!
    Feb 24, 2009
    871
    Rain City
    What are the lighting conditions you're shooting in?*EDIT- Just read both lighting conditions* Your probably getting the black shots from having the wrong aperture/shutter speed/ISO settings in manual mode. Try shooting in AV mode with a large aperture setting and continuous shooting enabled. If that doesn't work, you may want to have someone look at it who is familiar with a DSLR.
  4. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Instead of Manual mode, use shutter priority. In a bright area, crank up the shutter speed, waching the EV control through the view finder.
    I absolutly love shooting multiple exposures on the D90. It seems so fast.
  5. adolan20
    adolan20 TPF Noob!
    Dec 12, 2007
    261
    New Hampshire
    I don't think you can shoot continuous shots with the on camera flash so thus good lighting is a must.
  6. boogschd
    boogschd TPF Noob!
    Mar 19, 2009
    606
    ph
    higher f count + high shutter speed + low lighting = DARK Pictures
    [​IMG]
    #6 - whatever its called .. always try and position it in the middle...
    *thats what i do anyway
  7. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
  8. fiveoboy01
    fiveoboy01 TPF Noob!
    Dec 28, 2008
    684
    Waunakee, WI
    #6 is the light meter and getting it in the middle will produce a picture that's not over or under exposed. Sometimes I do not completely follow the meter though but for the purposes of just getting a picture, try to get it in the middle.
    It would be easier for you to shoot in A/S/P mode if you don't fully understand exposure, as you only have to deal with half of the exposure equation and the camera does the other half(if we're not counting ISO or if ISO is set to auto).
  9. Minissa
    Minissa TPF Noob!
    Mar 7, 2009
    40
    Alberta, Canada
    If you need more explanation or to simply surpass yourself, you should purchase these books from Bryan F. Peterson :
    -Understanding exposure
    -Understanding shutter speed
    :D
  10. john.kimin.kim
    john.kimin.kim TPF Noob!
    Jul 1, 2008
    17
    Right. If you boost up your shutter speed, in decrease the ISO, or the amount of light that can be put through the shutter speed. You need a brighter environment.
  11. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    First off, in order to get the full 3FPS shooting speed of the D60, you need to do the following:
    Press the MENU button, press left (to move the highlighted icon to the five boxes). Go to the camera icon and press OK, then go to where it says "Noise Reduction" and press OK. Change it to Off. Then go into the shooting menu (press the Info button), and press the + zoom key. Go to where it says "S" in a box, then change it to the next one down (three boxes behind each other). Press OK.
    Also, make sure your shutter speed is above around 1/250s. If you're in a bright environment, it'd be worth putting it on Program mode (be sure to put the flash down), and checking your shutter speed as you shoot. It may also be worth putting the lens into manual focus mode.
    That's about it, really, although it's really worth swotting up on a few photography books to help you understand when to force a high shutter speed, when to let it happen on its own, and when to simply admit defeat and keep to single-shot mode :p. I've heard very good things about the book "Understanding exposure".
how to make the Nikon d60 to take faster pictures
how to set a nikon d60 to take multiple pictures
how to set continuous shooting on nikon d60
how to take multiple pictures nikon d90
nikon 7100 wont take continuous images
nikon camera takes multiple pictures
nikon d60 continuous shooting
nikon d60 how to take multiple pictures
nikon d60 rapid shot
shoot continuous pictures with nikon d60
