Nikon F5 Mirror lock-up fault?
Discussion in 'Film Discussion and Q & A' started by stevec1234, Sep 19, 2007.
  1. stevec1234
    stevec1234 TPF Noob!
    Sep 19, 2007
    Hello forum, I'm Steve a new member.
    I purchased a second hand Nikon F% described as in perfect working order from a well known internet auction site. After I pressed the shutter release once the mirror locked up but did not return to the open position. The mirror lock up lever located to the right as the camera faces away from you, is not in the locked position and moving this does not do anything. I restored the factory settings on the computer and tinkered around with it but I cannot get the mirror to unlock.
    Steve
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Looks like the person running the auction forgot to send you the key to unlock it.......lol.
    Sorry, just trying to lighten the mood.
    Seems you got ripped off...
  3. stevec1234
    Sep 19, 2007
    I think your right, I will launch a despute with the auction site for the guy that sold it in 'perfect working order'!
    Steve
  4. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Wave when you see me go by.....
    I just tried mirror-up with my F3......Take out the battery pack and it should reset.
    Good luck...........
  5. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Or put batteries in the camera if it doesn't have fresh ones.
  6. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    I'd also suggest a fresh set of batteries to start with. Otherwise it may have a problem.
  7. stevec1234
    Sep 19, 2007
    Hi guys.
    They are fresh all the batteries (Duracell Pro Cell). I took them out the fault is still there. I noticed alot of scuffs around that catch (mirror lock up). I will lodge a dispute as the seller still has not got back to me. There is no way he ran a whole film through the camera before he sent it to check as it locked on the first shutter release depress.
    Steve
nikon f5 mirror locked up
nikon f5 stuck in mirror lock up
