Panoramic Photo Questions
Discussion in 'Photography Beginners' Forum' started by tranceplant, Sep 22, 2008.
  1. tranceplant
    tranceplant TPF Noob!
    Mar 6, 2005
    485
    So basically I never did a panoramic image but I am going to Japan for a 3week trip and of course my dSLR will be following and I think it would be interesting to try and make those cool panoramic images.
    So my first question is I will not bring a proper tri-pod, just a little 10cm pocket tri-pod if case of emergency. So do I need to bring a proper one to make those kind of images? (I have one, but I just don't feel like traveling with it)
    Also what kind of Software do you use or what software would you recommend in order to have good images ''stitched'' together?
    My objective is to get pictures like this one.
    http://www.panoramafactory.com/handheld.jpg
  2. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    You should probably consider taking the big-boy tripod. I don't think it's 100% needed but it'll definitely improve the quality and keep you from needing to crop the edges of shots that didn't line up correctly. I think you can force it through some programs (Photoshop comes to mind) misaligned but I'd try to use a tripod to ensure best quality.
    When I travel and can't take the bigger tripod, I'll take a gorillapod. They're more travel friendly and just as affective.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I haven't used any of the automatic stitching software, but there are some available. The newer versions of Photoshop have that options I think.
    The key is to lock your exposure / shoot in manual mode. That way, the exposure will be the same for all the shots.
    It's also good to use a focal length that won't give you too much distortion. I've also heard that it's better to shoot in portrait orientation and take more shots, than to shoot in landscape.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    since your example image has no close foreground with lots of detail, you will be finde handheld.
    if however, you shoot architecture in cities, with concrete patterns in front, complex structures, then a panorama head, which rotates around the nodal point of the lens, will remove parallax errors and allow flawless stitching.
    the tripod needs not to be very stable unless you plan long exposure panoramas.
    PanoramaStudio is a good piece of software which i use from time to time.
    These for example i did with PanoramaStudio:
    http://www.thephotoforum.com/forum/showthread.php?t=103047
    http://www.thephotoforum.com/forum/showthread.php?t=111245
    http://www.thephotoforum.com/forum/showthread.php?t=133260
    http://www.thephotoforum.com/forum/showthread.php?t=133353
    The last one was handheld, and you can see some flaws resulting from that.
    The first one would not have been possible without a nodal point tripod head.
  5. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
  6. tranceplant
    Mar 6, 2005
    485
    wow a lot of good information here... keep them coming. I will look for the gorillapod and also thank you mike for the time on locking the exposure and such. Didn't think of that, but it makes a lot of sense :)
