Pentax P30 - no cable release; what can I do?
Discussion in 'Beyond the Basics' started by Don Simon, Jul 30, 2005.
  1. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Hi all, I know this might be quite a specific question, but I was hoping that either someone has had experience of using this camera, or would know what to do with any camera that does not use cable release.
    Essentially the problem is this; I have looked all over the camera and can see nowhere that a cable release could go. The shutter button is just that - a button, with no hole, no thread. Until now this has never been a problem, but now I've tried using the camera with a 500mm lens I'm finding it impossible - the slightest touch causes camera shake which is very noticeable and would certainly mess up any photos I try to take. I was just wondering if anyone knows of some kind of "generic" cable release that could be used on this camera, or perhaps a way of improvising - the only thing I can think of is to use the self-timer, but needless to say with 10 seconds until the shutter is activated, this is not the most ideal solution unless the subject is completely stationary. I'd be extremely grateful for any suggestions, and can upload photos of the camera if that helps. Thanks in advance!
  2. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,373
    2,838
    In the mental ward of this forum
    I'm not familiar with this camera, but the Pentax MZ-S comes with a very proprietary (read: expensive) shutter release cable that I didn't buy for several months. The cable release socket was hidden under a plastic button I had to pry off the side to use. It's not at all the old-fashioned screw-on type; it's an electronic connection and it looks totally different.
    Check your user's manual; it might be a similar situation. An odd quirk for Pentax; annoying, too. In the meantime, I think your best bet is to use the self-timer. When was this camera manufactured? That might explain your difficulty.
  3. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    My Pentax P3 has a small thread hole on the side of the lens mount. Takes a standard plunger style cable release.
  4. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Thanks for the replies. The reason I'm pretty certain there's no release mechanism is that the manual (downloaded in PDF format) seems to make no mention of cable releases. At all. Anywhere. :( At least a "Cable releases cannot be used with this camera" would have been nice. It does seems surprising - I thought cable releases were pretty much standard. The manual is from 1985 so assume the camera was from the same year - it was certainly a mid-80s camera.
    Edit: Just Googled it again, found this... from
    http://www.bdimitrov.de/kmp/bodies/P/P3.html
    P3/P30
    "These are the first Pentax bodies without a thread for a mechanical remote release".
    Ahh... darn. I guess that means nothing can be done then. This really is hugely annoying, especially since up until now I thought this was the best camera I ever owned. In particular it means that the 500mm lens I bought for the camera is now just a useless piece of metal and glass - I guess I could use the self-timer, but only for taking photos of completely stationary subjects, and even then something in the composition will probably have changed in those 10 seconds. Like I said, darn :(
    Edit (again): Google just turned up this...
    http://www.trainweb.org/lfnwfan/html/AboutSite.htm
    in which someone claims to have taken photos on a "Pentax P30 body... using a tripod and a cable release".... Whaaaaaaaaaaat?!? So it has no thread for a cable release, but some guy used a cable release with it? I think I'll go lie down and wait for the world to rearrange itself into making sense.
  5. selmerdave
    selmerdave TPF Noob!
    Nov 30, 2004
    454
    Brooklyn, NY
    Don't fret, get another Pentax body that does have a release to use for that type of shooting. They are for the most part cheap enough (what's a K1000, $40?), a second body also comes in handy when you want to shoot two different kinds of film at the same time.
    Dave
  6. Dweller
    Dweller Inconspicuous Supporter
    Apr 19, 2004
    668
    Portland, Oregon
    I found this thread on a google search and it sounds like there is indeed a cable release, just not where you would expect to find it.
  7. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Thanks Dweller, but I'm pretty sure that poster made the same mistake many people seem to do online, of referring to the P30T or P30N as a "P30". The former two do have shutter release mechanism; after looking the camera and the manual over again I'm still convinced the latter doesn't. I'll most likely follow selmerdave's advice and buy a second body - there seem to be "generic" shutter releases available in the US for cameras without a release mechanism, but since these cost around $50 (not including shipping to the UK) I'll be better off just getting another body. Thanks anyway guys!
  8. fadingaway1986
    fadingaway1986 I Burn Easily :(
    Feb 4, 2004
    1,449
    9
    Queensland, Australia
    Isn't there one of those generic things that goes around the camera and uses pressure or something to push a button into the shutter button???
    Haha. That sounds dumb. Maybe someone will be able to help out here... I have seen people on here talk about them. they hook around the camera, and sit on top of the camera's shutter button...
  9. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
  10. fadingaway1986
    Feb 4, 2004
    1,449
    9
    yep - something like that.
  11. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Well it does look pretty cool; guess it could be used for P&S, as well as for those SLRs that want special remote releases costing about £50. I'd look for something on Ebay and Google, but I'd have no idea what search terms to use... Cable release & Heath Robinson, maybe :/
  12. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Well, never one to turn down an excuse to get more equipment, I decided to simply buy another body like selmerdave suggested - P30T in perfect condition for £30 including UV filter, lens, camera bag and manuals. Sometimes I really, really like Ebay :mrgreen:
pentax p3 remote
