Photoshop CS3 ext: adding text
Discussion in 'Photography Beginners' Forum' started by Nimitz, Jun 17, 2008.
  1. Nimitz
    Nimitz TPF Noob!
    Jul 12, 2007
    102
    Indialantic, FL
    Simple question: I'm adding some text to an image put want to orient the text at an angle other then horizontal or vertical to line up with something within the image.
    Can someone tell me how to orient text at an odd angle? Thanks
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    After entering the text and hitting enter, you can select the text as an object and it should have grips (to resize it). If you hold the cursor just outside the selected text, the cursor should turn into the rotate cursor...you can take it from there.
    At least that's how I remember it, off the top of my head.
  3. sunlioness
    sunlioness TPF Noob!
    Jun 9, 2008
    153
    Just arrived in the UK and I think I'm going to st
    Click the text on the Layers palette, then Edit/Transform/Rotate.
    Then if you go on Warp mode you have many presets to chose from.
  4. Nimitz
    Nimitz TPF Noob!
    Jul 12, 2007
    102
    Indialantic, FL
    That's got it, thanks!
