- Joined
- Mar 18, 2013
- Messages
- 15,468
- Reaction score
- 15,380
- Location
- Boston
- Can others edit my Photos
- Photos OK to edit
That’s an interesting idea. Wouldn’t the out of focus foreground lights end up in front of the subject instead of behind them though? Not necessarily a bad thing, just a different look.Did you try a set up in this order,
Camera - lights - subject? Where the lights are quite close to the camera and you make a shape out of wire to tie the lights to it and shoot through that shape. The OOF lights should bokeh quite nicely and you won’t need that many. Lots of examples abound on the interweb if it interests you.
Yes they do end up in front of the subject. This is why a simple stiff wire loop with the fairy lights attached to it allows you to avoid placing one in front of the subjects face. You also have the additional flexibility of moving the lights and/or your camera independently to get the desired effect. Placing the lights behind the subject means your variables are limited. A bit of grip gear to suspend the wired loop in the right place is pretty simple to set up.
This method has been used countless times as I am sure you have seen people using prisms and iPhone screens to add effects to the captured image. Adding fairy lights is just another spin on the same technique.
Great tip! This may save me from trying to make it work outside with my lit up trees as background.
