Polarizer filter question
Discussion in 'Photography Beginners' Forum' started by photosoto, Oct 31, 2009.
  1. photosoto
    photosoto TPF Noob!
    May 17, 2009
    202
    I know I"ve already posted a polarizer thread but I've got an important question.
    Would it not make more sense to get a larger filter than needed and use an adaptor in case I ever upgrade to larger lens?
    btw, I think I will be going with the either nikon or hoya multi coated glass lenses. :thumbup:
  2. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    It would make sense if you know the size of the lense you are getting in the future.
  3. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    it makes even more sense to just get a cokin system with a polarizer. works with any size lens, and you can work in some useful grad NDs easily. though it depends on what you are shooting... i do mostly landscape, so I have plenty of time to get myself setup with what is a bit of a cumbersome setup...
  4. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    That was what I thought recently - I have a bunch of lenses and all different filter sizes, so figured I'd buy a filter at the biggest size (77mm) and use adapter rings to 72mm, 67mm and 58mm so it would fit all my lenses. Unfortunately, I found that when using the filter on my 17-85 with the 67-72 and 72-77 adapters I get heavy vignetting at anything less than about 35mm focal length on the lens, due to the sort of 'hood effect' that the adapter rings give. Something to consider.
  5. DennyCrane
    DennyCrane No longer a newbie, moving up!
    Sep 11, 2009
    1,375
    34
    The arctic North Coast
    The only downside is, an adapter will move the filter away from the lens and you're risking vignetting at the edges.
  6. EhJsNe
    EhJsNe TPF Noob!
    Nov 23, 2008
    618
    A Riverside Town by Canada
    I never liked them stepup rings...they look odd and, as previously stated, you have the risk of vignetting.
    If the other lens youre getting is not going to be purchased in the near future, go with the proper sized filter, and when it comes time to get the new lens, get another polarizer with that one. (Having multiple filters also helps if you know what youre going to be shooting, so if you do have to change lenses, you dont have to also change filters, which is rather time consuming and annoying)
