After clearing the negative, wash it with running water at room temperature for about 5 minutes. For a more stable negative, rinse slightly longer than you would for a conventional negative. After washing, dip the negative in a Photo-Flow (1:600) solution and hang to dry. For optimal storage of the negative, use a glassine envelope.
To prevent scratches -- Negative scratch resistance can be improved by treating the processed negative (after clearing in water and sodium sulfite) with the hardener solution that comes with Kodak Rapid Fix for 2 minutes. The negative should be immersed in the hardener solution only, not the fixer (sodium thiosulfite) portion.
Jamie R said:Terri -
I wonder if this expired stuff would be a good idea to start trying to 'develop' the neg portion of the 55P/N in a wet solution dev. stop and fixer like other films. Would the quality be better than the jelly developer which the P/N comes in?
Worth a shot maybe?!
With proper processing and clearing, Type 55 negatives are every bit as stable as conventional negatives.
Development time and temperature are critical. At 70° F and above, the recommended processing time is 20 seconds. If in doubt about the actual temperature, it's better to overdevelop than underdevelop. Ordinarily, extending the processing time slightly will have little effect on image quality. On the other hand, underdevelopment may cause solarization in areas of minimum density.
Processing Information -- for best results, process at temperatures above 60°F (16°C).
Temperature Processing Time F/stop
Exposure Adjustment
75°+ F (24°+ C) 20 seconds none
70°+ F (21°+ C) 20 seconds none
65°+ F (18°+ C) 35 seconds none
55°+ F (13°+ C) 50 seconds none
50°+ F (10°+ C) 60 seconds none
It's probably a very expensive way to get a negative, but what a negative!
