Printer and calibration software help please
Discussion in 'Photography Equipment & Products' started by dl4449, Sep 13, 2008.
  1. dl4449
    dl4449 TPF Noob!
    Jun 7, 2008
    264
    San Jose,Ca
    I have a Samsung SyncMaster 226bw Lcd
    Vista home premium
    Canon Pixma ip4000
    First what calibration software will work for this monitor ?
    And would you recommend the Canon Pro 9000 printer
    The reason I ask is my photos are to dark and the calibration software that came with the Monitor does not want to work
    Thank you
    Troy
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Calibration software? What about calibration hardware. Visually calibrating a screen is almost impossible and gives rather poor results.
    With regards to the software none work with that screen. It has no adjustable lookup table, meaning the next question "which software will work with my videocard" is answered with "pretty much all of them" if you have a Nvidia or an Ati card. Same with the printer.
    Good software typically takes readings with a hardware sensor and asks you to make adjustments with the screen controls (if you're lucky your screen can do that automatically). Then the video card is adjusted so the gamma of the screen looks correct. Just note that with vista if the User Access Control window pops up you lose your calibration setting and you need to log out and log in again, or manually start the program which normally loads it to fix everything.
    Also note that you won't get a print to match a screen perfectly without proper hardware calibration AND proper viewing conditions, meaning a dedicated colour temperature controlled lightbox.
  3. dl4449
    dl4449 TPF Noob!
    Jun 7, 2008
    264
    San Jose,Ca
    Thank you Garbz I knew when I asked that question it would sound pretty stupid :blushing:
    I have acct control turned off so at least that shouldn't be a problem.
    My video card is a radeon X1950pro so i will look for calibration software for that.
    Do you know anything about the Canon 9000 printer i can pick one up for 399.00?
    Thanks again
    Troy
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No opinion on the quality of the printer. I have a Canon iP4200 which does make some nice prints already but it isn't economical for me to print at home. I can't imagine the 9000 being worse though :)
