Question about fiber based paper
Discussion in 'The Darkroom' started by stone_family3, Jan 10, 2010.
  1. stone_family3
    stone_family3 TPF Noob!
    Sep 15, 2009
    349
    Columbus Ohio
    I had someone give me 16 boxes of fiber based paper (new) and a almost complete darkroom set. However is there a way to flaten the paper once it is done drying? Our school has a press but at home is there something I can do like using an ironing board, place a towel over the print and using an iron?
    Usually I use RC paper but 16 boxes was a great gift and beggers can't be choosers...LOL.
  2. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    Dry them face down on clean drying screens, after they are dry, try pressing under a heavy stack of books. you could try the iron thing with the print between 2 sheets of of bristol board, but they won't be nice and flat as on a press and will take a while to do.
    Or you could bring them to school and press them there.
  3. stone_family3
    Sep 15, 2009
    349
    Columbus Ohio
    Thanks. I know I could press them at school but there is one press to 16-22 people. Plus mounds of pictures to press. I didn't lay them face down to dry I'll try that next time to see if that helps some.
  4. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    And you can make your own kind of press. Figure out what the paper you use doesn't stick to, put your prints between those, between two heavy duty pieces of wood that won't warp, with two sets of encyclopedias on top. You can get those at yard sales for about 5 cents a pound.
  5. Sbuxo
    Sbuxo TPF Noob!
    Aug 29, 2008
    978
    6
    Omgg lucky you got all that paper for free? Gimme some. Lol.
    Yeah, definitely dry them face down or else they will curl up. Mine are flat from being my heavy photo binder under other prints I have. They're in sheet protectors, but heavy books will do just fine.
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Step one is to not distort the paper in the first place.
    Most of the issues people have with difficult to flatten fiber based prints is caused by stretching the paper when it is wet. If you distort the fibers while wet it is all but impossible to ever get it to lie flat on its own.
    1. Never, under any circumstance, lift a wet print from one corner. When moving it from tray to tray lift it carefully from two corners. The larger the print the more critical this is as the larger prints are heavier when loaded with water and chemicals.
    2. Never, under any circumstance, squeegee a fiber print.
    If the dried print look like a lasagna noodle, you abused the print when wet. A properly handled fiber print should only display significan curl along one axis with very little or no rippling.
  7. Sbuxo
    Sbuxo TPF Noob!
    Aug 29, 2008
    978
    6
    I always squeegee my print front and back once each and it has never taken a 'lasagna noodle' look. It's just to remove excess water.
does fiber paper dry
how long do fiber prints take to dry
how long do you fix fiber based paper
how long does fiber paper take to dry
how long does it take for fiber paper to dry
how long for fiber paper to dry
how to dry fiber paper quickly
how to flatten fiber paper
ironing fiber prints
where to buy fiber based paper
