Require some advice please
Discussion in 'Photography Equipment & Products' started by Lexicon, May 14, 2003.
  1. Lexicon
    Lexicon TPF Noob!
    May 14, 2003
    Australia
    Hi, I am seeking some advice about the Minolta x-300 camera. I have the opportunity to purchase this along with the following for around $300 (australian): A digital readout in the view finder, auto photo etc. The lens is a Vivitar 55mm 28-70 with macro. The flash is a Sunpak Softlite 1600a. Also comes with a Hoya 55mm Skylight(1B)lens filter. I am a novice when it comes to this so any comments with regards to performance or anything would be much appreciated.
  2. vinnlandia
    vinnlandia TPF Noob!
    May 18, 2003
    12
    I haven't used one personally, but I know someone who has one, and it's apparently a very nice rig.
  3. jeffW
    jeffW TPF Noob!
    Jul 6, 2009
    86
    21
    dc
    Have you looked at where you will be developing the film for that matter buying fresh film? That said there are a lot of used film cameras for very cheap you might be better off setting your sights a bit higher and picking up a professional nikon body. (I'm not a Nikon shooter but know their old bodies were built tough) The other advantage would be a greater chance of finding used lenses. If you really want to go cheap the Pentax K-mount system has a lot of used lenses for sale.
    Honestly I think it's overpriced, the accessories don't add up. Very old flashes are going to be iffy. Look at a Nikon, you are going to find a lot more used lenses. Again not a nikon shooter not starting a brand war just looking at number of used accessories generally available.
  4. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,721
    411
    Looks a lot like my old Minolta SRT-101 with some added on electronics. It can do Aperture Priority metering (so you just set the Aperture on the lens and the camera will select the shutter speed to give the correct exposure). You can also set the shutter speed manually.
    The lens is basic, similar to a kit lens on todays cameras. There are plenty of very nice manual focus Minolta lenses out there, I always had a couple Rokkor-X lenses and it would help to have at least one fast prime lens as you will probably be using film in the ISO 100 to 400 range. The 50mm f/1.7 Rokkor-X is probably the cheapest (I think the -X designation was used in the U.S.). As the camera does not have automatic control of aperture it can probably use older Minolta lenses with no problem.
    Price seems a bit on the high side. I would think 200 Australian is a decent price. If it was the higher up X570 (or X500 depending on market) the price would be about right.
    However, if the camera is in very good condition then it is certainly a decent camera to use for learning photography or just having fun with film. It has a very good meter (typical of many Minolta cameras) and nice viewfinder equal to the their higher end models so it should be easy to focus. It will hold up to a lot of abuse for a plastic body camera. It can take a cable release (get one if you don't have one), but does not have a PC socket for external flash (have to use the hotshoe).
  5. SCraig
    SCraig Been spending a lot of time on here!
    Nov 12, 2011
    6,383
    2,390
    Nashville, TN
    13-year-old post. I suspect he has made up his mind by now.
  6. Dave442
    Feb 1, 2015
    1,721
    411
    Haha, I hope so!
  7. jeffW
    jeffW TPF Noob!
    Jul 6, 2009
    86
    21
    dc
    My Bad :icon_redface: I must not have my list set up right because it was at the top, didn't even think to look at the date.
  8. Dave442
    Feb 1, 2015
    1,721
    411
    A Zombie thread about a Zombie camera company :smile-new:
  9. zombiesniper
    zombiesniper The camera takes the Pic. I just point the way. Supporting Member
    Jun 23, 2015
    4,879
    3,028
    Angus, Ontario
    and replied to by a zombiesniper. :madass:
  10. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    For the love of the kittens in the world.......
