scanning radiographs with an epson V500 - help please
Discussion in 'Film Discussion and Q & A' started by cararomy, Apr 13, 2009.
  1. cararomy
    cararomy TPF Noob!
    Apr 13, 2009
    Hi,
    I bought an Epson V500 in order to be able to scan dental radiographs (X-ray films) for teaching purposes.
    I am aware that there is only a 3" approx column where to scan negatives - my problem is that the scanner after scanning insists on dividing my image into a lot of tine parts (negative or slide film size). the only options i can find is changing from 6x4.5 to 6x9.
    Is there a way for me to remove this default setting altogether and acquire a whole scan of 3" x 10"?
    thanks
    R
  2. randerson07
    randerson07 TPF Noob!
    Apr 4, 2008
    279
    Pingree Grove, Illinois
    Are you using the epson Software?
    If so its very simple, down under the preview butten there a a box with a checkmark on it that says thumbnail, simply uncheck that and hit preview. It will give you the entire strip. Now you have to tell the machine where the image is so you simply click and drag to select the image or images you want to scan.
can you use epson scanner to scan dental xray
dental radiograph scanner
epson v500 industrial film scanner radiography
epson x ray scanner
how to scan radiographs
radiograph scanner
radiograph scanners
scanner for dental radiographs
scanner for radiographs
