Sigma Flash or Canon Flash
Discussion in 'Photography Beginners' Forum' started by Derek Zoolander, Jan 23, 2009.
  1. Derek Zoolander
    Derek Zoolander TPF Noob!
    Dec 15, 2008
    300
    I'd like to get a flash eventually. And I'd like it if I could have 2 with one as a slave. Money is an issue, but if the Canon is THAT much better, I'll wait and save up.
    I'm looking at the Canon 580EX (which can be slave and master, right? while the 430ex can only be slave?)
    or
    The Sigma EX-500 DG Super. This is the equivalent to the Canon, right? I also saw that there is a EX-530 DG Super, which I'm assuming is even newer if numbers mean anything...
    Anyone with experience with either? I appreciate your help.
  2. Derek Zoolander
    Dec 15, 2008
    300
    also, can I use the Sigma EX-500 as both a slave and master?
  3. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    That's correct.
    From what I've heard, the Sigma flashes work well enough, but the build quality leaves a lot to be desired, especially when compared to the Canon units, which are pretty good.
    Are you dead set on using the built-in Canon wireless system? You could put together a two light, wireless off camera flash kit for less money than the cost of one 580EX (see HERE).
    There are pros and cons. With the Canon system, your slave flash is part of the E-TTL metering and can be controlled via the master. With radio triggering, your flash control will have to be manual...but it's really not that hard to figure out. Also, with the linked kit, you have two lights...both off camera. With the Canon system, you need to keep the master unit connected to the camera.
  4. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    That's correct.
  5. Derek Zoolander
    Dec 15, 2008
    300
    how often do you find yourself using the flash on camera?
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
    Events, parties, screwing around....Mostly off camera for me though.
    Strobist: Lighting 101
  7. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    I actually use my 430EX on camera quite a bit...and I would certainly recommend owning either a 430EX or a 580EX. However, if my goal was off-camera flash (especially on a tight budget) then I'd certainly go with the cheaper units and radio trigger set up.
  8. Derek Zoolander
    Dec 15, 2008
    300
    Can I not use the Sigma as an on camera flash?
  9. Derek Zoolander
    Dec 15, 2008
    300
    nevermind...we're talking about if i bought that strobist unit...
