lostartsalon
- Joined
- Mar 23, 2015
- Messages
- 2
- Reaction score
- 0
Hello!
I'm using a Canon EOS Rebel T2i with Smith-Victor AC Slave Flash umbrellas + light mount. There's a Hana adapter on the hot shoe, which is plugged directly into one of the flash bulbs. The issues are as follows:
- The flash only fires every 4 shots
- When it does fire, often only one bulb goes off- usually whichever one is plugged into the cable attached to the camera
Both bulbs have been changed very recently. I was previously using a Calumet Wireless Flash Trigger, but that stopped working (when it began firing every 4th time), so I switched to the direct plug-in situation I'm in now.
Because it fires only every 4th shot, no matter what the hook-up to the flash is, does that mean it's an issue with the camera? The camera works just fine without flash/ in natural lighting. I've had this set-up for about 3 years now, is it just time for some new gear?
Any help is much appreciated!
Michelle
Michelle
