SCraig
- Joined
- Nov 12, 2011
- Messages
- 6,474
- Reaction score
- 2,450
- Location
- Nashville, TN
- Website
- sc-photo-tn.com
- Can others edit my Photos
- Photos NOT OK to edit
I was sitting at work today holding my little portable disk drive and it got me thinking about days long past.
I worked for an engineering company back in the 80's and 90's and was system manager (that was the previous name for network administrator which was the previous name for IT manager) for their CADD system. We used a DEC VAX 11/785 which was Intergraph's OEM implementation of the VAX 11/780. The computer had (4) 19" wide racks so it was about 6.5' wide by about 6' tall and 4' or so deep. It had far less computing capacity than my cell phone does today. We had to keep everything in a climate-controlled room because everything gave off so much heat. Without a dedicated air conditioning system everything started to overheat after about 30 minutes (I know because our air conditioner failed a few times).
What really got me thinking was the disk drive though. We used two CDC 6775 disk drives that were about 38" tall by 42" deep by 24" wide and weighed 635 pounds each. They ran from 208v 3-phase power and as I recall required a 30-amp dedicated circuit. Their total storage capacity was 675 megabytes each.
My little portable drive runs from 5 volt power from the USB bus, and is about 3" x 4.25" x 0.65" and weighs 7 ounces. It has a capacity of 2 terabytes or the same capacity as about 3,104 of those CDC 6775 drives.
3,104 CDC 6775 drives would weight about 985 tons, use about 27 megawatts of electricity (about 74,000 amps at 208v 3-phase) and would require about 40,332 square feet to house them (they can't be placed right against each other front to back, a 36" depth was required behind them).
I think, but it's been a long time, those drives cost us about $10,000 each so 3,104 of them would have cost $31,040,000 in 1990 dollars as opposed to the $120 I paid for my 2tb portable drive.
The computer would probably be along the same lines as far as cost, size, and computing capacity goes. I suspect my cell phone has several hundred times the computing abilities as that VAX did.
The times have definitely changed!
