Is it worth upgrading from a crop frame to a full frame or get a better lens than a current lens?
Sent from my iPhone using Tapatalk
Im doing wedding photography. And there are times where theres a lot of limited lighting. But half have good lighting too. But im thinking for the other 50% or more of the time where there is limited lighting.
I'm currently using Canon EOS 1100d.
Ef - 50mm f/1.8 and 75-300mm
Ef-s 18-55mm, 24mm f/2.8
If your business model includes cost of equipment both as a line item and as an annual budget, then you would know how much you should spend for it.I've not mentioned a budget because I'm not entirely sure as to how much I should spend for it.
