UV Filter & Polarizer?
Discussion in 'Photography Beginners' Forum' started by fdrotary, Jul 5, 2009.
  1. fdrotary
    fdrotary TPF Noob!
    Mar 26, 2009
    14
    I recently got a Polarizer as a gift from someone and decided to read a little about them on the forum. I never even thought about the fact that all polarizers weren't created equal and since mine was $20 i am pretty sure it's not all that great. Now i am curious though, are all UV filters created equal or do i need to get different ones?Thanks and if you could link a good polarizer and UV filter from B&H photo? I am assuming they ship to APO addresses but my connection here is horrid and it takes me about 5mins per page.Ps. Random wide angle question Sigma 10-20, or Canon 10-22? which is better?
  2. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    This should help.
    Tiffen | 52mm Digital HT (High Transmission) Circular | 52HTCP
    Hoya | 52mm Circular Polarizing Pro 1Digital | XD52CRPL | B&H
    B+W | 52 mm Circular Polarizer Multi-Coated (MC) | 66044838
    Hoya | 52mm Circular Polarizer (HMC) Multi-Coated | A52CRPL
    Any UV filter really will be fine. For me I use them only to add a layer of protection onto my lens. Any will surely work just fine.
    As Far as the lens. Either would be fine though it really depends on which f/? you would be getting. Canon's higher end line seems to be better than most lenses, though Sigma is making some good glass theses days.
    Cheers.... Hope this helps.
  3. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    Adding a UV filter also adds an air gap that can contribute to lens flare. A low quality UV filter can also degrade your image quality to some extent.
    A lens hood protects your lens front element from bumps and so forth while also helping to minimize lens flare and increase contrast. That's why good lenses come with a hood. A cheap lens hood won't degrade your image quality.
    If your lens did not come with one, get a lens hood instead of a UV filter.
