What film scanner?
Discussion in 'Beyond the Basics' started by darin3200, Jan 17, 2006.
  1. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    I'm in need of a film scanner and could use some suggestions. It doesn't need to be some insane resolution, all I really need is a way to get my negatives on the internet without having to print 5x7s and scan them because printing a lot drives me nuts. Color doesn't need to be great, B&W all I really need. Also under $200 is preferable.
    Thanks!
  2. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    I have a KonnicaMinolta DiMage Scan Dual IV that I like. I have also heard good things about the Plustek Opticfilm 7200.
    It's kind of hard to find film scanners at low (<$500) prices, and these are about the only two I know of that are around $250. It seems to be a pretty unpopular price bracket for the manufacturers. But these two scnners are good (I know first hand with the Minolta, and I've heard from people about the Plustek).
    I think there are also ones around the $50-100 range but their quality is probably not so great.
  3. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Thanks, I'll look into those
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    I own a Acer Scanwit 2720s that I've had good luck with. It's only 2700dpi, but does a decent job. That's the lowest I would go. It's SCSI, not USB, but comes with a card. Kind of old now, so I'm sure there's better out there, but it should be cheap if you need to go that way.
    http://www.photoscientia.co.uk/Review.htm
    2720S
    2740s with digital ICE
  5. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    I'm going to be different and recommend a flatbed, since you say you don't need high resolution and just want to get the images on the internet. A flatbed designed to handle negatives (with a negative holder and backlight) will cost less than a dedicated film scanner, may be quicker if it uses high-speed USB, and can handle 35mm negatives and slides as well as medium format. I use the CanoScan 8400F and scan 8 negs at a time, at 3200dpi. Here's a link to a similar post from a few days back; scroll down for an example of a negative scanned with this scanner...
    http://www.thephotoforum.com/forum/showthread.php?t=38285
    Obviously that's not the only option in flatbeds; Epson apparently do very good flatbeds with neg-scanning capability and I'm sure there are equally good ones from other manufacturers too. All I'm saying is don't automatically discount the flatbed option, especially if budget is a concern.
