TopPop
I received my IR filter for my D70 a couple of days ago, and haven't had much time to use it yet, but I've been reading up on the best ways to acheive good results.
I read that to get trees their whitest, I need to use a custom WB setting, using a spot of grass as the "white". However, do I set this "white" with or without the IR filter on? I guess that I'm trying to ask if I should set a true green as the "white", or a "true" green as the camera will see it through the filter. Does that make any sense?
Thanks for any help that you can give!
Cheers,
Chris
Cheers,
Chris
